It has not updated.
It should be just like uploading a code into your RA.
Make sure to disconnect the Ecotech RF radio.
Radion help
Re: Radion help
hadnt taken it out before, i have now. however, i get the same message
Can it be that I am running windows 8? I had to add the libusb0 file
Re: Radion help
Are you sure you are using COM1?
You must update the file to use the correct com port.
Same one you use to upload codes to your RA.
Re: Radion help
Thanks Roberto, got it to work (reinstalled the reef angel installer and used another com). Got that working, but struggled tonight to make the Vortech sync (got them to sync in theory, but then did not turn white). Will try some more tomorrow.
Re: Radion help
Tried some more today. I can't get the pumps to sync. I get the blue and red light all the time (error) even when the RF module is a couple of inches away. I tried at least 5 times in each of the 2 MP40 pumps. What can I do?
Re: Radion help
This is the error I'm getting trying to sync my quiet drive driver...i'm using the bus lock firmware you gave me
