Radion help
Re: Radion help
I thought that maybe you could change the value of the variable in the memory, that way you are still using the memory but can start different modes at different times. Is that it?
Re: Radion help
This is what I use:
But I just found a bug...
You need to add this to your code generated by the wizard or the feature doesn't get enabled:
//ReefAngel.RF.SetChannel
ReefAngel.RF.ChannelWhiteSlope();
ReefAngel.RF.ChannelRoyalBlueSlope();
ReefAngel.RF.ChannelRedSlope();
ReefAngel.RF.ChannelGreenSlope();
ReefAngel.RF.ChannelBlueSlope();
ReefAngel.RF.ChannelIntensitySlope();
if (hour()>=15 && hour()<=18)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(LongWave,100,3);
ReefAngel.DCPump.SetMode(ShortWave,100,50 );
else if (hour()>=22 || hour()<=7)
ReefAngel.RF.SetMode(ReefCrest,40,0);
ReefAngel.Relay.Off(Koralia1);
ReefAngel.Relay.Off(Koralia2);
ReefAngel.RF.UseMemory=true;
Re: Radion help
Thanks Roberto. That is very similar to the code I have for the pumps. I am not sure what happens with the Radions in the priods of time where you have "ReefAngel.RF.UseMemory=false"
When I added the line: ReefAngel.RF.SetChannel I get the following error when compiling "error: statement cannot resolve address of overloaded function"
I also notice that you have it as a comment with the "//" in your code.
Re: Radion help
Thanks! I will test this tonight and come back if I have any issues
Re: Radion help
Lucho, did you get this to work? I'm having the same issues as you had. I reset my radions to basic mode and it's still not receiving from my RA
Re: Radion help
If you didn't get it to work, Roberto just released a firmware update that fixed my issue (and maybe yours too)
Re: Radion help
Thanks Alex. I cant make it work, though. I get this, and the RF light doesnt blink in the process (it does when I first connect it). Is there a way to check if this updated? Thanks!
C:\Users\Downloads\RF_Update_New_Radion>avrdude -Cavrdude.conf -v -patme
ga328p -carduino -P\\.\COM1 -b115200 -D -Uflash:w:RF_Update_New_Radion.hex:i
System wide configuration file is "avrdude.conf"
Using Port : \\.\COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude done. Thank you.
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
Re: Radion help
It has not updated.
It should be just like uploading a code into your RA.
Make sure to disconnect the Ecotech RF radio.
Re: Radion help
hadnt taken it out before, i have now. however, i get the same message
Can it be that I am running windows 8? I had to add the libusb0 file
Re: Radion help
Are you sure you are using COM1?
You must update the file to use the correct com port.
Same one you use to upload codes to your RA.
Re: Radion help
Thanks Roberto, got it to work (reinstalled the reef angel installer and used another com). Got that working, but struggled tonight to make the Vortech sync (got them to sync in theory, but then did not turn white). Will try some more tomorrow.
Re: Radion help
Tried some more today. I can't get the pumps to sync. I get the blue and red light all the time (error) even when the RF module is a couple of inches away. I tried at least 5 times in each of the 2 MP40 pumps. What can I do?
Re: Radion help
This is the error I'm getting trying to sync my quiet drive driver...i'm using the bus lock firmware you gave me
