RANet Dimming Module! Usage?
Re: RANet Dimming Module! Usage?
rimai wrote:yes. you don't need to do anything to the dimming module except configure your dimming signal voltage
Got it running. I took the daughterboard off to set the jumpers and couldn't figure out which way it went back. It was nice of you to make it only fit one way. :lol:
I'll probably hook up my Jebao's tonight or tomorrow. I think I'll wait on hooking up the LED's. I still need to study the hi resolution dimming, etc.
If you connect the wrong way, you can't close the box.
rimai wrote:If you connect the wrong way, you can't close the box.
So I found out! That's good design!
bencollinz
Post by bencollinz »
is this still the case? and where do I do that? and are the pin layouts the same as the PWM dimming module?
bencollinz
cosmith71 wrote:Yup. Look here on page 5.
http://www.reefangel.com/files/Dimming% ... _1.4.2.pdf
Thank you.
So, I'm OK if I put my wires in the same place on the new RAnet dimming as the old wired dimming?
Here you go:
bencollinz
cosmith71 wrote:Here you go:
thank you
