I've had an issue with one of my relay ports toggling on an off for no reason.
I think it maybe related to the wifi module. What I've noticed Is that the relay toggles very quickly every 10 to 15 minutes and if I remember correctly my RA updates the portal every 10 to 15 minutes. Could I have a problem with the wifi module cord or the module itself?
Relay on off and wifi module
Re: Relay on off and wifi module
I wouldn't think so.
Post your code. Do you know which relay it is?
Hey Colin,
I'm using internal memory but here's my code. I think it's the relay on box 1 port eight.
Another thing that's annoying is happening, when I turn a port off with my android tablet, I'll here the relay toggle and the port that I turned off will turn on by itself.
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.MoonLights( Port1 );//sump light
ReefAngel.DayLights( Port2 );//top fuge light
ReefAngel.CO2Control(Port5);
ReefAngel.StandardATO( Port6 );
ReefAngel.DayLights( Port8 );//lights fan
ReefAngel.DosingPumpRepeat1( Box1_Port5 );
ReefAngel.DosingPumpRepeat2( Box1_Port6 );
ReefAngel.Portal( "elevatorguy1", "****");
Port 8 on the expansion box? Strange. Maybe the VGA cable to the relay box has a bad connection? It really doesn't look like a software problem.
