wifi troubles
aqua man 07
wifi troubles
Post by aqua man 07 »
so ill start by saying im not a computer programer. i tried the wifi utilty and it wont work if it even conets to the wifi attachment it will say err unplug and try again. so once i finaly get it to go on to where i enter my ssid and key it says it wont connect. if there is no easy way to set this up im just going to sell it if i dont smash it into pieces first. any help would be great.
Re: wifi troubles
Are you sure you are selecting the correct serial port?
Is the wifi blinking green and blue?
Can you click "Copy to clipboard" and paste the results in here?
aqua man 07
Re: wifi troubles
ill try to see what i can figure our
aqua man 07
Re: wifi troubles
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM4
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 -1 0 index.htm
< 11 74976 3 WiFly_GSX-2.19
< 30 -1 10 config
< 31 75992 3 WiFly_GSX-2.21
< 50 86328 3 wifly-GSX-400
< 184 Free, Boot=50, Backup=31
< <4.00>
> set c c 0
< set°c lØ0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< ÿÙº c o 0
< AOK
< <4.00>
> set c i 3
< set°c i 3
< AOK
< <4.00>
> set c s 1420
< set°c nÈ1420
< AOK
< <4.00>
> set d n www.reefangel.com
< set d n ww7™·ÛÙ³angel.com
< AOK
< <4.00>
> set i h 198.171.134.6
< set i h 198.171.134.6
< AOK
< <4.00>
> set i r 80
< ÿÙt i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< ÿÙº i p 2
< AOK
< <4.00>
> set o d ReefAngelWifi
< set o d ûÛÛ³AngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s MyCharterWIFI-2G
< ÿÙº w s MyCharterWIFI-2G
< AOK
< <4.00>
> set w p huskyraccoon920
< ÿÙº w p huskyraccoon920
< AOK
< <4.00>
< set w k 000000000000p0000000000000
< AOK
< <4.00>
< ûe|ftp address 198.175.253®161
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< shoÿ n
< SSid=MyCharterWIFI-2G
< Chan=11
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=192.168.0.13:2000
< NM=255.255.255.0
< GW=192.168.0.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1460
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router N600 Wireless Dual Band Gigabit Router-Premium Edit.
Port 2000 is now being forwarded to 192.168.0.13
Re: wifi troubles
is it still blnking blue?
aqua man 07
Re: wifi troubles
well that doesnt look right but thats what it coppied
aqua man 07
Re: wifi troubles
yes
Re: wifi troubles
And you are positively sure that you are typing the ssid and passphrase in the same case, correct?
They are both case sensitive.
One thing you can try is to remove the - in your SSID and use only alpha numeric characters.
Also, for best compatibility, use WPA2-PSK with AES encryption in your router security settings. This is the most secure one too.
aqua man 07
Re: wifi troubles
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 -1 0 index.htm
< 30 -1 10 config
< <4.00>
> set c c 0
< set°c lØ0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< ÿÙº c o 0
< AOK
< <4.00>
> set c i 3
< set°c i 3
< AOK
< <4.00>
> set c s 1420
< set°c nÈ1420
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> set i r 80
< ÿÙt i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< ÿÙº i p 2
< AOK
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< shoÿ n
< Chan=11
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.0.1
< PROTO=TCP,
< MTU=1460
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< ûgboot
aqua man 07
Re: wifi troubles
i get this all the time also
aqua man 07
Re: wifi troubles
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 -1 0 index.htm
< 30 -1 10 config
< <4.00>
> set c c 0
< set°c lØ0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< ÿÙº c o 0
< AOK
< <4.00>
> set c i 3
< set°c i 3
< AOK
< <4.00>
> set c s 1420
< set°c nÈ1420
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> set i r 80
< ÿÙt i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< ÿÙº i p 2
< AOK
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< shoÿ n
< Chan=11
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.0.1
< PROTO=TCP,
< MTU=1460
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< ûgboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ló
< FL# SIZ FLAGS
< 2 -1 0 index.htm
< 30 -1 10 config
< <4.00>
> set c c 0
< set c c 0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< set c o 0
< AOK
< <4.00>
> set c i 3
< set c i 3
< AOK
< <4.00>
> set c s 1420
< set c s 1420
< AOK
< <4.00>
< set d n www.reefangel¿ãom
< AOK
< <4.00>
< set i ü 198.171.134.6
< AOK
< <4.00>
> set i r 80
< set i r 80
< AOK
< <4.00>
> set i f 0x6
< set°{ f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< set i p 2
< AOK
< <4.00>
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s MyCharterWIFI2G
< set w s MyChart6nµiãI2G
< AOK
< <4.00>
< set w p èuskyraccoon920
< AOK
< <4.00>
< set  k 0000000000000000000°00p000
< AOK
< <4.00>
< set ftp address 1ïœ.175.253.161
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=MyCharterWIFI2G
< Chan=11
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.0.1
< PROTO=TCP,
< MTU=1460
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Re: wifi troubles
Did you change the ssid in your router to be without the - too?
You have to type the exact same thing as your router or it won't work.
aqua man 07
Re: wifi troubles
yes i took the - out
aqua man 07
Re: wifi troubles
thank you
