wifi troubles
aqua man 07
Re: wifi troubles
Post by aqua man 07 »
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM4
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 -1 0 index.htm
< 11 74976 3 WiFly_GSX-2.19
< 30 -1 10 config
< 31 75992 3 WiFly_GSX-2.21
< 50 86328 3 wifly-GSX-400
< 184 Free, Boot=50, Backup=31
< <4.00>
> set c c 0
< set°c lØ0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< ÿÙº c o 0
< AOK
< <4.00>
> set c i 3
< set°c i 3
< AOK
< <4.00>
> set c s 1420
< set°c nÈ1420
< AOK
< <4.00>
> set d n www.reefangel.com
< set d n ww7™·ÛÙ³angel.com
< AOK
< <4.00>
> set i h 198.171.134.6
< set i h 198.171.134.6
< AOK
< <4.00>
> set i r 80
< ÿÙt i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< ÿÙº i p 2
< AOK
< <4.00>
> set o d ReefAngelWifi
< set o d ûÛÛ³AngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s MyCharterWIFI-2G
< ÿÙº w s MyCharterWIFI-2G
< AOK
< <4.00>
> set w p huskyraccoon920
< ÿÙº w p huskyraccoon920
< AOK
< <4.00>
< set w k 000000000000p0000000000000
< AOK
< <4.00>
> set ftp address 198.175.253.161
< ûe|ftp address 198.175.253®161
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< shoÿ n
< SSid=MyCharterWIFI-2G
< Chan=11
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=192.168.0.13:2000
< NM=255.255.255.0
< GW=192.168.0.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1460
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router N600 Wireless Dual Band Gigabit Router-Premium Edit.
Port 2000 is now being forwarded to 192.168.0.13
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< ûgboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ló
< FL# SIZ FLAGS
< 2 -1 0 index.htm
< 30 -1 10 config
< <4.00>
> set c c 0
< set c c 0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< set c o 0
< AOK
< <4.00>
> set c i 3
< set c i 3
< AOK
< <4.00>
> set c s 1420
< set c s 1420
< AOK
< <4.00>
< set d n www.reefangel¿ãom
< AOK
< <4.00>
< set i ü 198.171.134.6
< AOK
< <4.00>
> set i r 80
< set i r 80
< AOK
< <4.00>
> set i f 0x6
< set°{ f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< set i p 2
< AOK
< <4.00>
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s MyCharterWIFI2G
< set w s MyChart6nµiãI2G
< AOK
< <4.00>
< set w p èuskyraccoon920
< AOK
< <4.00>
< set  k 0000000000000000000°00p000
< AOK
< <4.00>
< set ftp address 1ïœ.175.253.161
< AOK
< <4.00>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=MyCharterWIFI2G
< Chan=11
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.0.1
< PROTO=TCP,
< MTU=1460
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Re: wifi troubles
Did you change the ssid in your router to be without the - too?
You have to type the exact same thing as your router or it won't work.
aqua man 07
Re: wifi troubles
yes i took the - out
aqua man 07
Re: wifi troubles
thank you
