Jabeo WP-25 Wavemaker
Re: Jabeo WP-25 Wavemaker
ok now it is making more sense. Still not sure what syn/ant-sync is but i think here is the mapping of Jabeo to RA:
H1/H2/H3 = Constant
W1/W2/W3/ = Short / Long Pulse
Else = Reef
Speed S1/S2/S3 = Not sure - on WP-25 this is a seperate feature then the Dial.
Dial = RA Speed setting?? I think. On WP-25 this controls speed on constant setting and also the pulse duration
H1/H2/H3 = Constant
Else = Reef
The modes the RA uses don't really translate to the Jebao modes.
Also you can't assign different modes to each pump.
It's also not recommend to use a wave mode on the DC return pumps.
Ok now you just through me for a loop. Are you saying I can't do this:
WP-25 (in display tank and power head/wave maker)
- relay 5
- Dimmer 1
-Want to put in short or long pulse
- On power up - want to turn on and set mode to short/long pulse with set speed
- On feed mode want to turn off and return to mode it was in before
Speedwave (return pump)
- Relay 1
- Dimmer 2
- On power on - slowly ramp up like it does now and then constant mode at full speed
- On feed mode want to reduce the speed to 1 and then return to what it was
If that is the case then I think they owe me a refund for the Jebao cable I bought for my Return pump - it will be useless to me since I can basically only turn it on/off and would keep the jebao controller hooked up
- relay 5
- Dimmer 1
- Relay 1
- Dimmer 2
You can do all those things.g6gang wrote:Ok now you just through me for a loop. Are you saying I can't do this:
- relay 5
- Dimmer 1
- Relay 1
- Dimmer 2
The return pumps don't have a quick response like the powerheads do, so you can't use them as a quick response wavemaker, but just adjusting speeds like you're wanting to do will be fine.
Yes you can do that.
I thought you wanted to run the speedwave in else mode while the WP25 is in short or long pulse.
The slowly ramp up to speed is a function of the pump not the controller.
The pump automatically does that.
The Speedwave can be set to a percentage of full speed during feed mode like 30%.
I'm not sure how to code a different speed for the speedwave and the WP25 during feed mode.
I'm pretty sure it can be done though.
To set the 25 to off during feed mode you can use this.
What you may have to do is turn relay 5 off during feeding and set the DC pump to 30%.
But I'm sure some of the better codes then me can give you a better way to do what you want.
ReefAngel.DCPump.FeedingSpeed=30;
Sacochen - I think you are correct, I only see a way to make one instance of the DCPump class
Roberto - can you please provide instructions for how to control and use two DC pumps seperately?
You set the type of pump on each port...
ReefAngel.DCPump.DaylightChannel=Anti-Sync;
Then you set DCPump to the speed, mode, duration you want.
The docs are DOxygen. You can download that tool and run it against the source code. Look at Steve's PDE in his signature above. He's got different cycles throughout the day etc.
For Feeeding Mode, you just need to do ReefAngel.DCPump.FeedingSpeed=0;
Keep asking questions, if the docs dont' work for you, we can help.
Thanks Lnevo
That is what I thought and won't work in my situation:
DC Pump1 - Pulse mode (it is my wavemaker in tank)
DC Pump 2 - Constant mode (it is return pump)
Still not clear on what is Sync/AntiSync. Where is this explained??
So looks like sadly you cannot control two DC pumps to behave differently.
I want something like
ReefAngel.DCPump.ActinicChannel.mode = constant
ReefAngel.DCPump.DaylightChannel.mode = Reefcrest
The DCPump class was made to make it easier to control multiple pumps. You can easily do what you want and it's what we had before we had the DCPump class.
Sync and Anti-Sync - if you look at how the Vortech pumps work, then you will see that any pump in sync will work at the same speed. Any pump in Anti-Sync will be the corralary speed depending ont he wave form. So in some modes if Sync is at 80% Anti-Sync will be at 20%
There is a thread on the wave modes we have, what you can do is simply..
ReefAngel.PWM.SetActinic(80);
ReefAngel.PWM.SetDaylight(ReefCrestMode(80,20,true));
It makes sense now why you're confused. I would not consider the DCPump class suitable for a return pump. The DCPump class was designed for the wavemakers.
The great thing about ReefAngel is that there is a way to do everything.
It might now be exactly the way you are thinking, but it can be done.
There have only been a hand full things I asked for or about that I've been told no you can't do that and it's normally a hardware related issue.
ok I think lnevo answered my question. I was looking at the wrong class for my return pump. I will use DCPump for my WP-25 and the PWM for my return pump. I have not tried any of this yet so maybe it will be more clear when I start playing with it.
One last thing I am not clear on - when the wizard asks me "In the code" or "in the internal memory", do both of these options ensure that after the RA loses power it will come up with the code I upload..I am afraid that I will hook all this up and not be home when power goes out and then the return pump does not come back on.
The RA stores all the code on the unit so after a power outage it comes back up as if nothing happened.
If you do hard coded you need to upload new code to change certain parameters. If you choose memory it will let you adjust those through the wifi. For new users and troubleshooting we recommend starting with hard coded values and then graduate later to memory. It also depends on your level of comfort with coding.
