Need Help with WIFI
mng777777
Need Help with WIFI
Post by mng777777 »
I cannot figure out the Wifi configuration. I am getting this with the utility:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM5
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM5
< CMD
> ls
< ls
< FL#    SIZ   FLAGS
<   2  86328   3 wifly-GSX-400
<   4  74920   3 web_app-GSX-106
<   7  46632   3 wps_app-GSX-131
<   9  66240   3 eap_app-GSX-101
<  11  37282   0 web_config.html
<  21    512   0 link.html
<  24   1052  10 config
<  25  88548   3 wifly-GSX-441-r1057
<  26   1052  10 user
<  27  88548   3 wifly-GSX-441-r1057
< 122 Free, Boot=25, Backup=27
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s 51brewster
< set w s 51brewster
< AOK
< <4.41>
> set w p 12345678
< set w p 12345678
< AOK
< <4.41>
< set w k 00000000000000000000000000
< AOK
< <4.41>
> set ftp address 198.175.253.161
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=51brewster
< Chan=6
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router TC8305C
Port 2000 is now being forwarded to 0.0.0.0
I followed the Tera Term instructions, but it just sits with a blank screen after I connect the module on both baud rates. I am not sure what to try next???
Please help!
Re: Need Help with WIFI
You don't need to.
I'm pretty sure your wifi is already setup.
If it is only blinking green, it is already connected and running.
mng777777
Post by mng777777 »
Okay... I figured out how to navigate Tera Term and I read the module's configuration. It is as Follows:
<4.41> get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-55
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.10:2000
NM=255.255.255.0
GW=10.0.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=75.75.75.75
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=51brewster
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=12345678
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
get e
SSID=WiFly-GSX-55
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=10.0.0.10:2000
NM=255.255.255.0
GW=10.0.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=75.75.75.75
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=51brewster
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=12345678
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Does anything stand out as being incorrect and if so, how do I go about correcting it?
mng777777
Post by mng777777 »
You are correct! It is working now, I just needed the correct IP address which wasn't shown in the utility but I found as I was reading through the config I just posted
