#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardATO( Port1,20 );
ReefAngel.StandardLights( Port3,18,0,10,0 );
ReefAngel.StandardHeater( Port7);
ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,21,0,10,55,180,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(7,5,21,5,10,45,180,10) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(7,10,21,10,10,55,180,10) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(7,15,21,15,10,45,180,10) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(7,20,21,20,10,55,180,10) );
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
ReefAngel.PWM.SetActinic( ElseMode(70,30,false )); // ElseMode on anti-sync mode, 70 +/- 30%
ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+70,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+108, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+70,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+108, y+20,1);
char buf[16];
// Temp and PH
y+=10;
ReefAngel.LCD.DrawLargeText(T2TempColor, DefaultBGColor, x+5, y+12, buf, Num8x16);
ReefAngel.LCD.DrawLargeText(T3TempColor, DefaultBGColor, x+40, y+12, buf, Num8x16);
y+=5;
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,10,18, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,33,18, 10 );
int t=x;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
lights not coming on
jjdezek
i set up my new light dimming module and the lights arnt coming on. i have anolog controllers and plugged all the bus connectors on the left side. here is my current code.
Re: lights not coming on
Can you open the module and check a lone jumper?
It must be off.
There were a few modules that were shipped with that jumper on.
It must be off.
jjdezek
jjdezek
jjdezek
Well I thought that was a fix. My lights were on but now there not turning off. Am I missing part of the code that says when they should come on and when they should turn off?
- cosmith71
jjdezek
They were still pretty bright this morning and I believe my drivers don't kick on until 10. Maybe I need to change it to 8 or 9
- cosmith71
I'd start at 0 to test.
What kind of drivers?
