my code
#include <SoftwareSerial.h>
#define Heater 1
#define Return 2
#define HeaterTk2 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
#define Sump Light 8
byte vtechmode, vtSpeed, vtDuration;
ReefAngel.FeedingModePorts = Port2Bit;
// ReefAngel.FeedingModePortsE[0] = 0;
// ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
// ReefAngel.WaterChangePortsE[0] = 0;
// ReefAngel.LightsOnPorts = 0;
// ReefAngel.LightsOnPortsE[0] = 0;
// ReefAngel.OverheatShutoffPortsE[0] = 0;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
// Hardcode calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
ReefAngel.SalMax=3300; // 35ppt
vtechmode=InternalMemory.RFMode_read();
vtSpeed=InternalMemory.RFSpeed_read();
vtDuration=InternalMemory.RFDuration_read();
static unsigned long feeding;
ReefAngel.StandardHeater( Port1,778,782 );
ReefAngel.WaterLevelATO( Port7,180,71,74 );
ReefAngel.StandardLights( Port8,15,0,2,0 );
ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) ); //MOON
ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) ); //RB
ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) ); //BLUE&CYAN
ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
if ( ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
// if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
// ReefAngel.RF.SetMode(ReefCrest,60,20);
feeding=now();
if (now()-feeding<5400) {
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,75,10);
ReefAngel.RF.SetMode(Constant,10,0);
if (vtechmode!=InternalMemory.RFMode_read())
InternalMemory.RFMode_write(vtechmode);
if (vtSpeed!=InternalMemory.RFSpeed_read())
InternalMemory.RFSpeed_write(vtSpeed);
if (vtDuration!=InternalMemory.RFDuration_read())
InternalMemory.RFDuration_write(vtDuration);
ReefAngel.Portal( "bencollinz" );
char text[7];
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
ReefAngel.LCD.Clear(255,59,29,128,39);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
/* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
// water level
ReefAngel.LCD.DrawText(0,255,68,58,"WL");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
/* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
