Multi-Channel Water Level Expansion reads 0
Trevenator
Post by Trevenator »
My Multi-Channel Water Level Expansion reads 0.
It has been working fine since I got it.
Today all channels are reading zero.
If I try to celebrate it just says zero
I have unplugged it plugged it to other ports on the usb hub.
I have rebooted the reef angle several times and have reprogramed it with the wizard.
Any ideas or do you think it just went bad?
Re: Multi-Channel Water Level Expansion reads 0
Check for any signs of water damage.
Trevenator
No obvious signs water damage.
I did not think there would be because its in a sealed part of the stand away from any water for electronics only.
Do you think humidity could travel up the air lines and cause condensation inside ?
