Wifi trouble
Re: Wifi trouble
Did you check if you have that line in your code?
I think your port forwarding is correct.
You just need to send data to the server to update to your latest ip address.
The one showing in the portal is from several months ago and it most likely have changed since.
Everytime you send data to the server, it updates that ip address. So, it is very important to have your controller send data to the server.
HodagReef
Re: Wifi trouble
Post by HodagReef »
I will check the code in a few hours, when I get home. One thing I did notice during the Wifi device set-up is that I never receive the message – Now forwarding to IP XXX.XXX.XXX.XXX. I remember that I received this message during the set-up last year. Does this mean anything?
HodagReef
Re: Wifi trouble
Post by HodagReef »
Ok, I just went ahead and ran the RA wizard again. Now I'm getting error when I try to upload to the controller
I copied what was at the bottom of the RA wizard:
Wifi Attachment
2014 Main Screen
pH Expansion Module
Water Level Expansion Module
Simple Menu
RA_Preloaded:83: error: stray '\' in program
RA_Preloaded.cpp:87:61: error: too many decimal points in number
RA_Preloaded.cpp: In function 'void setup()':
RA_Preloaded:47: error: 'class ReefAngelClass' has no member named 'FeedingModePortsE'
RA_Preloaded:50: error: 'class ReefAngelClass' has no member named 'WaterChangePortsE'
RA_Preloaded:53: error: 'class ReefAngelClass' has no member named 'LightsOnPortsE'
RA_Preloaded:56: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'
RA_Preloaded.cpp: In function 'void loop()':
RA_Preloaded:83: error: 'Your' was not declared in this scope
RA_Preloaded:83: error: expected `;' before 'DDNS'
Reef Angel Libraries Found: Development
Reef Angel Libraries Version: 1.1.1
   What can I do to fix this issue?
Re: Wifi trouble
Post your code, please.
HodagReef
Re: Wifi trouble
Post by HodagReef »
Here is what the RA wizard generated:
ReefAngel.WaterChangePorts = Port5Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.WavemakerRandom( Port5,105,75 );
ReefAngel.StandardHeater( Port7,756,766 );
ReefAngel.Portal( "HodagReef" );
ReefAngel.DDNS( "HodagReef" ); \ Your DDNS is HodagReef-174.xxx.xxx.xxx.myreefangel.com
Wifi trouble
Your DDNS line is wrong. It is supposed to be a comment but a backslash by mistake. Change the \ Your DDNS to // Your DDNS
Re: Wifi trouble
Should it be //?
Re: Wifi trouble
Oh yeah :)
HodagReef
Re: Wifi trouble
Post by HodagReef »
Ok - at work now but will change later tonight. Thanks everyone for the help. For my education, did I cause this? or did the RA wizard generated the error?
Re: Wifi trouble
he will probably need to remove the Expansion relay lights, overheattemp, etc variables since he does not appear to have an expansion relay box. i cannot post the exact code right now because im on my ipad, but im sure others know what i am talking about and can help out.
billw
Re: Wifi trouble
Post by billw »
lnevo wrote:Your DDNS line is wrong. It is supposed to be a comment but a backslash by mistake. Change the \ Your DDNS to // Your DDNS
The wizard's code generator does that. I've experienced the same thing. I solved it by just leaving that field blank in the RA wizard.
Re: Wifi trouble
The RA generated this error, but the newer release has this bug fixed.
You can grab the lastest here:
http://www.reefangel.com/update/files/t ... Wizard.jar
Overwrite the one located in your \Documents\Arduino\tools\Wizard\tool folder
Reefology
Re: Wifi trouble
Post by Reefology »
HodagReef wrote:Ok - at work now but will change later tonight. Thanks everyone for the help. For my education, did I cause this? or did the RA wizard generated the error?
It was the wizard. I had the same issue a few days ago that drove me batty :twisted: All good now :D
Reefology
Re: Wifi trouble
Post by Reefology »
Thanks for the update Roberto. however, I am now getting 2 other errors?
'class ReefAngelClass' has no member named 'DDNS'
'class ReefAngelClass' has no memeber named 'Use2014 screen'
billw
Re: Wifi trouble
Post by billw »
rimai wrote:The RA generated this error, but the newer release has this bug fixed.
Thanks, Roberto!
Re: Wifi trouble
Reefology wrote:Thanks for the update Roberto. however, I am now getting 2 other errors?
Are you using Arduino on your linux or Windows?
Reefology
Re: Wifi trouble
Post by Reefology »
Lol, thought you might ask that. I use both but test trial runs on linux before creating and unloading on windows. Because I got the error, never bothered to try it on windows. So these error are sticky on a linux system?
Re: Wifi trouble
No its not normal. Theres something wrong in your setup or the code. Does it compile on the windows box?
HodagReef
Re: Wifi trouble
Post by HodagReef »
Update - back up and running. Thanks for the support!
