The wizard's code generator does that. I've experienced the same thing. I solved it by just leaving that field blank in the RA wizard.lnevo wrote:Your DDNS line is wrong. It is supposed to be a comment but a backslash by mistake. Change the \ Your DDNS to // Your DDNS
Wifi trouble
Re: Wifi trouble
Re: Wifi trouble
The RA generated this error, but the newer release has this bug fixed.
You can grab the lastest here:
http://www.reefangel.com/update/files/t ... Wizard.jar
Overwrite the one located in your \Documents\Arduino\tools\Wizard\tool folder
Re: Wifi trouble
It was the wizard. I had the same issue a few days ago that drove me batty All good nowHodagReef wrote:Ok - at work now but will change later tonight. Thanks everyone for the help. For my education, did I cause this? or did the RA wizard generated the error?
Re: Wifi trouble
Thanks for the update Roberto. however, I am now getting 2 other errors?
'class ReefAngelClass' has no member named 'DDNS'
'class ReefAngelClass' has no memeber named 'Use2014 screen'
Re: Wifi trouble
Thanks, Roberto!rimai wrote:The RA generated this error, but the newer release has this bug fixed.
Re: Wifi trouble
Are you using Arduino on your linux or Windows?Reefology wrote:Thanks for the update Roberto. however, I am now getting 2 other errors?
Re: Wifi trouble
Lol, thought you might ask that. I use both but test trial runs on linux before creating and unloading on windows. Because I got the error, never bothered to try it on windows. So these error are sticky on a linux system?
Re: Wifi trouble
No its not normal. Theres something wrong in your setup or the code. Does it compile on the windows box?
Re: Wifi trouble
Update - back up and running. Thanks for the support!
