RA Net with Relay doesn't seem to be working correctly.
Re: RA Net with Relay doesn't seem to be working correctly.
Power control is [0] and your relay box would be [1].
But I don't think it is that.
Maybe it is the RANet Add-On that is not good. I had to replace Sacohen when he sent me his stuff to troubleshoot.
I could never find out what the problem was.
I think it was a bad baking of the pcb when it went to the oven for reflow.
I'm assuming that you can't reprogram the RANet module either, right?
Do you mean reflash the firmware? I don't know but I can give it a try. I think I saw some step by step here somewhere, I'll see if I can find it again.rimai wrote:I'm assuming that you can't reprogram the RANet module either, right?
Btw, are you referring to the sender or receiver? I only found instructions for reprogramming the receiver: http://forum.reefangel.com/viewtopic.php?p=45104#p45104rimai wrote:I'm assuming that you can't reprogram the RANet module either, right?
The blue led on RSSI lights up when connecting the cable but in Arduino studio I get error uploading (w/ optiboot). See below for full output.
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
Can you try uploading without the xbee module?
If that doesn't work, we may need to get you another board.
Exactly the same error without the module mounted, but the RSSI LED did not light up.
Yeah, we may need to replace.
I'm going to make a small batch.
I have a RANet wireless dimming module. For the past 2 days the lunar module connected to the wireless dimming module is not working. I think the dimming module is not syncing with the head unit. Can I reprogram the receiver in the wireless dimming module? I had done this to the receiver in the wireless relay box earlier when there were syncing problems.
Dr Davaraj
Dr Davaraj
I get the exact same error when I try to reprogram the receiver on the dimming module. I also get the same error without the xbee module installed. The RSSI LED lights up for a fraction of a second when the code uploads before it fails.phrusher wrote:The blue led on RSSI lights up when connecting the cable but in Arduino studio I get error uploading (w/ optiboot). See below for full output.
avrdude: Version 6.0, compiled on Apr 6 2012 at 19:29:19 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf" Using Port : \\.\COM3 Using Programmer : arduino Overriding Baud Rate : 115200 Rebooting Reef Angel Controller avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Recv: avrdude: stk500_getsync(): not in sync: resp=0x64 avrdude done. Thank you.
Dr Davaraj
Any progress on the new batch?rimai wrote:Yeah, we may need to replace.
Huh.. Totally missed this
I'll work on this.
I'll work on this.
