RA Net with Relay doesn't seem to be working correctly.
davaraj
Re: RA Net with Relay doesn't seem to be working correctly.
Post by davaraj »
phrusher wrote:The blue led on RSSI lights up when connecting the cable but in Arduino studio I get error uploading (w/ optiboot). See below for full output.
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude done.  Thank you.
I get the exact same error when I try to reprogram the receiver on the dimming module. I also get the same error without the xbee module installed. The RSSI LED lights up for a fraction of a second when the code uploads before it fails.
Dr Davaraj
phrusher
Post by phrusher »
rimai wrote:Yeah, we may need to replace.
I'm going to make a small batch.
Any progress on the new batch?
Huh.. Totally missed this :(
I'll work on this.
