RF Expansion Vortech Control Issue
alexwbush
Post by alexwbush »
FIXED: Put into feeding mode, then exit. Vortech follows controller's inputs.
BLUF: Synced properly. I've tried changing to different modes within the portal, no change to speed or mode. Runs constant speed. Any thoughts?
Details: I followed the instructions for resetting my Vortech MP40wES and put it into the slave mode. I uploaded the Vortech setup code into my controller and synced the MP40. The MP40 shows white on the dial with blue in the meter. After, I uploaded my code and it doesn't seem to be following any of the modes I've tried. It just runs constant. The RF module has a solid green light.
Here's my code:
    ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.WaterLevelATO( Port4 );
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.Relay.DelayedOn( Box1_Port5 );
    ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port8 ) );
    ReefAngel.RF.ChannelWhiteSlope();
    ReefAngel.RF.ChannelRoyalBlueSlope();
    ReefAngel.RF.ChannelRedSlope();
    ReefAngel.RF.ChannelGreenSlope();
    ReefAngel.RF.ChannelBlueSlope();
    ReefAngel.RF.ChannelIntensitySlope();
    ReefAngel.Portal( "alexwbush" );
Side note:
In the instructions, it says to go to: http://ecotechmarine.com/media-gallery/ ... tech-pump/
It should say go to: http://ecotechmarine.com/media-gallery/ ... rtech-pump
alexwbush
Re: RF Expansion Vortech Control Issue
Post by alexwbush »
Nevermind. For anyone experiencing a similar issue, here's what I did to fix it:
Put your controller into feeding mode and your Vortech should go into feeding mode. Then clear it, now it works!
