RF Expansion Radion Control Issue
Re: RF Expansion Radion Control Issue
Follow up question: Should the buttons on the radion work in basic mode if it's receiving programming from the RA RF module? My buttons are non responsive and I've made sure that they are enabled.
I cycled the power for the radions and did another factory reset. I think it's in basic mode. First color temperature has all LEDs on at 100% and I can cycle through the color temps. How do I get the RA to control it now?
I'm definitely in basic mode and can cycle through light temperatures, but none of them are what the RA is transmitting (50% intensity, 100% red... that's it for testing). For anyone who has gotten this to work, am I missing a step??
That should be it.
Basic mode is all that is needed.
What about the vortech pumps? Are they working?
Vortech pump is responding to code and works fine. RF module shows fading while and matches night mode on the Vortech. Do you think I need to reset the controller and start over? Maybe get the Radions to work before Vortech?
No, they work independent of each other.
If you issue feeding mode in the Radions, does RA and/or pumps go into feeding?
Yes, that worked no problem.
It does not. The only indication I have that we're in feeding mode is the light pattern on the Vortech. My normal pumps that turn off during feeding mode did not respond. I don't think the RA knows we're in feeding mode.
Anyone else have any ideas? I don't want to give up on this thing.
Out of ideas
Basic mode is all it is needed. I've been using it for a long time now.
I can try to start from scratch. Maybe reset my RA and try to get the radions working before the vortech. Is there a good basic code we know works for radions?
What code can I add to use the variables that I can control in the portal for intensity for the different channels?
I think instead of this:
I could use:
ReefAngel.RF.SetChannel( Radion_Green, 100 );
ReefAngel.RF.SetChannel( Radion_Intensity, 50 );
ReefAngel.RF.UseMemory = true;
/* For testing purposes. Set intensity of colors by the End % of each channel in RA Portal. Code doesn't do anything with Start % or Duration(m)
ReefAngel.RF.SetChannel( Radion_White, InternalMemory.RadionSlopeEndW_read() );
ReefAngel.RF.SetChannel( Radion_RoyalBlue, InternalMemory.RadionSlopeEndRB_read() );
ReefAngel.RF.SetChannel( Radion_Red, InternalMemory.RadionSlopeEndR_read() );
ReefAngel.RF.SetChannel( Radion_Green, InternalMemory.RadionSlopeEndG_read() );
ReefAngel.RF.SetChannel( Radion_Blue, InternalMemory.RadionSlopeEndB_read() );
ReefAngel.RF.SetChannel( Radion_Intensity, InternalMemory.RadionSlopeEndI_read() );
So, I think that worked. But still not able to get the radions to change based on what I do to the RA.
Anything else you can think of that you had to do to make the radions work Roberto? I've messaged a bunch of people and haven't found anyone else able to get this to work
Troubleshooting continues...
So after you do a factory reset, does it pick up the RA's RF module signal right away? Or does it go to 10k/14k/whatever and you have to press something? I'm 99% sure I am in basic mode as I can change modes from 6.5k-20k, but still not seeing what the RA RF is sending.
Do I need to update firmware on the RF module? http://forum.reefangel.com/viewtopic.ph ... n&start=20 ...if so, I don't have the libusb0.dll and I cannot quite figure out what I am supposed to do to add that.
I just went through the same thing and found a copy of libusb0 on line. Of course all the standard caveats when getting something on line. I'd suggest you wait until Roberto confirms that an update may help before taking that chance.alexwbush wrote:Troubleshooting continues...
Do you use radions? Had a similar issue with getting them to respond to the RA RF? What worked?? My wife thinks I am getting obsessive about getting this to work.billw wrote:I just went through the same thing and found a copy of libusb0 on line. Of course all the standard caveats when getting something on line. I'd suggest you wait until Roberto confirms that an update may help before taking that chance.
Also, do you have some good instructions to get the libusb0 working? I tried one set of instructions and still get the error.
I was troubleshooting the bus lock up issue and Roberto suggested that the firmware upgrade would be necessary. In that case the firmware upgrade appeared to have worked. On the libusb0 issue, I went to dll-files.com and downloaded the 32 bit version. I placed it in the directory where I had unzipped Roberto's files. I have a new laptop so I was willing to take a bit more of a risk. If I hosed the whole system, I could just rebuild it without much loss. Please be careful, I did take a risk as my familiarity with dll-files.com is minimal. IMO it's not worth it until you confirm that the firmware update is needed In your case.alexwbush wrote:Do you use radions? Had a similar issue with getting them to respond to the RA RF? What worked?? My wife thinks I am getting obsessive about getting this to work.billw wrote:I just went through the same thing and found a copy of libusb0 on line. Of course all the standard caveats when getting something on line. I'd suggest you wait until Roberto confirms that an update may help before taking that chance.
Specifically on the Radions, I just haven't got there yet. I'm still fooling with them with Ecosmart Live. I'm bring a 240 gallon tank on line and I have higher priority things to do at the moment. As always, Roberto is your best source for info there. Obsession is what this hobby is all about! Best of luck in getting your Radions on line, I'll be following with hopes of benefiting from your experience.
No, that is not related to the bus lock.
When I find some time, let me try updating my radions firmware and see what I can come up with.
It's been a long time.
Maybe I'll try to update the RF module. I'm not sure what else to do at this point. I took the lights off and put the RF module nearby, still nothing. My radions are updated on firmware, so I'm not sure if that's a problem or not.
Thanks bill. I was able to get the .bat file running and the RF module appeared to take it (red lights flashing and all), but still not able to control the radions. I know the EcoSmart Live works well, but I wanted to be able to put the lights into different modes at will (20k, actinics only, moonlight, etc.). Hopefully Roberto can think of something. I don't know what else to try. The bit of annoying hassle is that now I'll probably reprogram the light with EcoSmart Live so that the fish get their normal light cycle back, after it's been 100% 10k for 6-8 hrs. I'll have to reset it every time I want to try and mess around with fixing this thing againbillw wrote:I was troubleshooting the bus lock up issue and Roberto suggested that the firmware upgrade would be necessary. In that case the firmware upgrade appeared to have worked. On the libusb0 issue, I went to dll-files.com and downloaded the 32 bit version. I placed it in the directory where I had unzipped Roberto's files. I have a new laptop so I was willing to take a bit more of a risk. If I hosed the whole system, I could just rebuild it without much loss. Please be careful, I did take a risk as my familiarity with dll-files.com is minimal. IMO it's not worth it until you confirm that the firmware update is needed In your case.
Here is my current .pde. If it works properly, the radions should display 100% green (only color) at 75% intensity:
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.LightsOnPorts = Port2Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.MoonLights( Port2 );
ReefAngel.WaterLevelATO( Port4 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.Relay.DelayedOn( Box1_Port5 );
ReefAngel.Relay.Set( Box1_Port6, !ReefAngel.Relay.Status( Port8 ) );
// ReefAngel.RF.UseMemory = true;
// ReefAngel.RF.ChannelWhiteSlope();
// ReefAngel.RF.ChannelRoyalBlueSlope();
// ReefAngel.RF.ChannelRedSlope();
// ReefAngel.RF.ChannelGreenSlope();
// ReefAngel.RF.ChannelBlueSlope();
// ReefAngel.RF.ChannelIntensitySlope();
//ReefAngel.RF.SetChannel
/* Auto feeding mode starts.
Feeder set for 12:00, start feeding mode at 11:55. */
if ( hour() == 11 && minute() == 55 && second() ==0 ) //if time is 11:55:00
ReefAngel.FeedingModeStart(); //start feeding mode
/* Vortech nutrient transport mode (after feeding mode)
// Turn off nutrient transport mode
if (ReefAngel.Relay.Status( Port2 )== 0 && ReefAngel.RF.Mode==Night)
ReefAngel.RF.SetMode(Night_Stop,0,0);
// Turn on Night Mode if Fuge light is on (Fuge comes on at night)
if (ReefAngel.Relay.Status( Port2 )== 1 && ReefAngel.RF.Mode!=Night)
ReefAngel.RF.SetMode(NutrientTransport,75,40);
/* Vortech night mode
Info: you can do ReefAngel.Relay.Status(Port2); which will return 0 (off) or 1 (on) */
// Turn off Night Mode
ReefAngel.RF.SetMode(Night,20,0);
ReefAngel.Portal( "alexwbush" );
So, I had the same problem has you. And since ecosmart does a pretty good job, and I don't have Vortechs, I just sent my RF unit back in for credit and bought the Jebao battery backup.alexwbush wrote:Maybe I'll try to update the RF module. I'm not sure what else to do at this point. I took the lights off and put the RF module nearby, still nothing. My radions are updated on firmware, so I'm not sure if that's a problem or not.
I don't think it's anything on reef angel's end. I updated my Radion software and since then I can't even get the demo to work properly.
I think it's a Radion problem, and not Reef Angel.
Hell, EcoTech might have got pissed and decided to code it to keep Reef Angel and Apex from controlling it, since they have the Ecosmart Wi-Wi thing now.
I think your best bet is just use Eco-Smart and wait it out. Im sure Roberto will find a cure.
Thanks for your insight! I wonder if there is any way to remove the firmware updates or set them way back to factory defaults.Lionfan wrote:So, I had the same problem has you. And since ecosmart does a pretty good job, and I don't have Vortechs, I just sent my RF unit back in for credit and bought the Jebao battery backup.alexwbush wrote:Maybe I'll try to update the RF module. I'm not sure what else to do at this point. I took the lights off and put the RF module nearby, still nothing. My radions are updated on firmware, so I'm not sure if that's a problem or not.
Anyone able to get this to work with current Radions? It sounds like it worked once upon a time with old old Radion firmware and there isn't a way to go back.
Ok, try this update.
You can find the instructions on how to update the RF firmware in here:
http://forum.reefangel.com/viewtopic.php?p=13002#p13002
- RF_Update_New_Radion.zip
- (425.28 KiB) Downloaded 527 times
Thanks for working on this Roberto. I'll try it out and let you know!
WORKS! Thanks Roberto! I'll update the first post with solution. I think there were 1-2 other threads where people had the same issue.
I didn't even have to reset my Radions to basic mode. It took over the programmed lighting.
Roberto, some bad news. The code appeared to work, but after running it for a week or so, I am finding issues.
1. Vortech no longer synced: The Vortech no longer syncs. I thought it was all running fine until I noticed after being gone the last 5 days that the Vortech is running on one speed with a white dial. I just ran the VortechSetup code again and tried to sync it... no luck.
2. Radions stay on after light cycle: I noticed while away that the lights worked fine during the day and then ran some weird random programs after hours. One day it was 3 hours past light cycle and instead of being off, it was daylight. The portal showed 0% for everything, but it was still on. Most days the blues stay on, as if an extended sunset. The only time they'll stay off is if I cut the power to the radions and turned them back on.
I'm running the same firmware now on my own radions.
I updated them to latest firmware, which indeed make them not work like you had stated before.
So, I updated the firmware of the RF module and I've been running it since that day with no problems. I did bring them back to basic mode though.
