Water level expansion issues
Re: Water level expansion issues
According to the RA both are. I can visually see the overflow changing. I'm not to sure about the return, its harder to tell. Yeah like right now it goes from 40 to 41 constantly and every now and then (about 10 seconds) it will hit 39 and 42.
And your durso is doing that too? I would say your not getting good flow in the durso if thats happening. Definitely not normal. My durso changes but very slowly, not noticable at all. I would say try sticking the airline in and adjusting till thats gone, drilling a bigger hole or adding. I doubt the return pump would fluctuate that much on its own.
Maybe it is the pump, because my return looks the same, except mine travels much more. I think it travels about 3/4".
But I also adjust the speed, that's why I'm not so sure.
Yeah my durso does it too. I will try the airline or drilling a bigger hole. I'm going to try another non-DC pump to see if it is the pump itself.
Ok, I drilled another 1/4" hole and that seems to have done the trick. Thanks for the suggestion.
