Roberto is there any reason that My DC Pump would stop working withthe 1/9 dev code?
After getting the WL working and calibrated I noticed that the WP-40 I got from you a couple of months ago wasn't working.
I tried a different Jebao cable and a different channel (Daylight instead of Actinic) both didn't work, so to check the pump I connected it to the stock controller and it worked fine.
So I decided to try the 12/31/14 dev code I had and the pump continued to work, so leaving everything plugged in and working I changed back to the 1/9 dev code and the DC pump stopped working.
I put it back to the 12/31/14 dev code, because the only problem I had there was I wan't able to hit OK or Cancel on the WL calibration, but since it is now calibrated I don't need it right now and I'd rather have the DC pump working.
Let me know what you think and if I can just copy a folder or something from the 1/9 dev code into the 12/31 code.
Thanks;
Steve
Water Level will not calibrate
Re: Water Level will not calibrate
I was not able to replicate.
What mode were you using?
Here is the code I used:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.DCPump.SetMode( ShortPulse,50,500 );
I'm using a random mode generator the lnevo created.
I don't know what mode it was in at the time. The Portal is set to custom.
I'm having this problem again, after reformatting my PC last month.
Unfortunately It's not clear what I did to resolve it last time.
I'm using the libraries from the current installer.
It looks like I wound up using libraries from a 1/9/15 GitHub release. I can;t find them again.
When I just use the libraries from the current installer I get the following error of compiling.
'time_t does not name a type' from this portion of my code...
// Does not need to be global.
// unsigned long ATOUpdate=0;
static time_t LastATO=millis(); // For de-bounced ATO
Before I reformatted my PC I copied over the libraries I had working and when I copy them back to the Arduino folder it will compile and upload, but the problem with the Water Level Calibration remains.
