Great idea! Now I just need a half dozen of these things!
How do you connect to Reef Angel Controller? Do you use a long bus cable?
Water Level Expansion: Pipe length
Re: Water Level Expansion: Pipe length
1/2 dozen of the Water Level sensors?
Roberto developed a multi Water level senor that has 4 units in it, so that plus the original single unit will give you 5.
That is the max you can have I believe.
I have the units mounted in my stand with all my other equipment and I'm going to use long tubing to the unit to the PVC tube.
Ah, I didn't know you could extend the 1/4" tubing. Any idea how long it can be?
I haven't tried it yet. I'm looking at about 20'.
I already extended 1 to 10' to reach the 10 gallon ATO tank I have set up now.
