No Comm to Portal
No Comm to Portal
So,
I finally was able to get an internet provider that allowed me to port forward.
I have access to my controller with reeftronics, the U-app, the Reef Angel Status app.
But, the controller is NOT talking to the portal.
I would rather use the portal, than use reeftronics.
Any help?
I did a factory reset on both the controller and the wifi attachment.
Any help?
Re: No Comm to Portal
Make sure you have ReefAngel.Portal("Lionfan") line in your code.
If it is already there, are you familiar with Tera term or putty to dump the settings of the WiFi attachment?
the code is correct, and not at all familiar with the tera term or putty..
OK, let's try updating the settings then.
Follow instructions here :
will do once i get home!
I was reading that earlier, and had a feeling thats what i needed to do.
I'll also check my code to make sure "Lionfan" is correct
there might be a chance it's not capitalized right or something
i did both.. Still no comm to portalrimai wrote:OK, let's try updating the settings then.
Can you post your entire code?
Also, connect the usb programming cable into RA and open serial monitor on tools menu and make sure it is set to baud 57600.
Wait 5 to 10 minutes and post what you see in the window.
rimai wrote:Can you post your entire code?
ReefAngel.CustomLabels[0]="50 Gallon Return";
ReefAngel.CustomLabels[1]="240 Gallon Return";
ReefAngel.CustomLabels[2]="Heater";
ReefAngel.CustomLabels[3]="Fan";
ReefAngel.CustomLabels[4]="Refugium Light";
ReefAngel.CustomLabels[5]="Skimmer";
ReefAngel.CustomLabels[6]="Calcium";
ReefAngel.CustomLabels[7]="Carbonates";
ReefAngel.CustomLabels[8]="ATO";
ReefAngel.CustomLabels[9]="Daylights";
ReefAngel.CustomLabels[10]="Actnics";
ReefAngel.CustomLabels[11]="Moonlights";
ReefAngel.CustomLabels[12]="Reactors";
ReefAngel.CustomLabels[13]="Open";
ReefAngel.CustomLabels[14]="Powerhead";
ReefAngel.CustomLabels[15]="Powerhead";
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardFan( Port4 );
ReefAngel.MoonLights( Port5 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.SingleATOLow( Box1_Port1 );
ReefAngel.Portal( "Lionfan" );
waiting on the serial monitor
Here it isLionfan wrote:waiting on the serial monitor
üGET /status/submitp.aspx?t1=784&t2=784&t3=739&ph=1057&id=Lionfan&em=8&em1=2&rem=1&bid=1&key=&ddns=&af=0&sf=0&atohigh=0&atolow=0&r=35&ron=0&roff=255&r1=254&ron1=0&roff1=255&pwma=0&pwmd=91&pwmao=255&pwmdo=255&sal=60&dcm=2&dcs=0&dcd=40&dct=30
That looks correct.
I'm really out of ideas.
RA is sending the data to the wifi attachment, which should send it to the portal, but for some reason it is not.
The only weird thing is that 1st character before GET.
If you leave serial monitor open, does it show again?
No, it pops up as soon as i open up the monitor, but doesnt repeat...rimai wrote:That looks correct.
this morning i got a blinking status light on the head unit.
everything is still running, and I'm still getting data sent to reeftronics.
Don't know what's going on..
That means a bus lock probably.
If you use the joystick to the status screen, what does it show?
What expansion modules do you have connected?
Earlier today, everything looked the same when i scrolled thru.rimai wrote:That means a bus lock probably.
The only expansion module right now is a relay box.
I had the bus lock yesterday, it cut off my second relay box.rimai wrote:That means a bus lock probably.
I disconnected the expansion hub, and got the bus lock to go away. but now I'm without the 2nd box.
still having problems with no portal comm.
Is there anything you can do on your end to see if maybe the portal just isn't updating?
I don't see nothing wrong on this end. Portal has been updating for other members.
When you have some time, send me a PM and we can schedule a remote session.
Roberto,rimai wrote:I don't see nothing wrong on this end. Portal has been updating for other members.
It's lionfan..
I created a new account, and changed the code on the controller, and I still don't have any data going to the Portal..
I did it the night we had the remote session, and still nothing.
This username was giving the same crap as we experienced that day.
So, I knew something was up.
But I finally found the bug
Can you let me know if it is working now and you can switch back to lionfan
Yelp it's working now!rimai wrote:This username was giving the same crap as we experienced that day.
You da man!
I'll switch back tonight and delete this name.
