No Comm to Portal
Re: No Comm to Portal
That looks correct.
I'm really out of ideas.
RA is sending the data to the wifi attachment, which should send it to the portal, but for some reason it is not.
The only weird thing is that 1st character before GET.
If you leave serial monitor open, does it show again?
No, it pops up as soon as i open up the monitor, but doesnt repeat...rimai wrote:That looks correct.
this morning i got a blinking status light on the head unit.
everything is still running, and I'm still getting data sent to reeftronics.
Don't know what's going on..
That means a bus lock probably.
If you use the joystick to the status screen, what does it show?
What expansion modules do you have connected?
Earlier today, everything looked the same when i scrolled thru.rimai wrote:That means a bus lock probably.
The only expansion module right now is a relay box.
I had the bus lock yesterday, it cut off my second relay box.rimai wrote:That means a bus lock probably.
I disconnected the expansion hub, and got the bus lock to go away. but now I'm without the 2nd box.
still having problems with no portal comm.
Is there anything you can do on your end to see if maybe the portal just isn't updating?
I don't see nothing wrong on this end. Portal has been updating for other members.
When you have some time, send me a PM and we can schedule a remote session.
Roberto,rimai wrote:I don't see nothing wrong on this end. Portal has been updating for other members.
It's lionfan..
I created a new account, and changed the code on the controller, and I still don't have any data going to the Portal..
I did it the night we had the remote session, and still nothing.
This username was giving the same crap as we experienced that day.
So, I knew something was up.
But I finally found the bug
Can you let me know if it is working now and you can switch back to lionfan
Yelp it's working now!rimai wrote:This username was giving the same crap as we experienced that day.
You da man!
I'll switch back tonight and delete this name.
