Does this reset at midnight?
In other words, if it is a number not divisible evenly by 24 hours in a day, is the last dose skipped, or will it offset the next day?
Dosing Pump Repeat Interval Time
Re: Dosing Pump Repeat Interval Time
I believe in the current state it will offset, but I'm not 100% sure
It resets at midnight.
So, if it is not even, you will get the last dose and the first dose (always midnight) with a little less time apart from each other.
