Dimming Expansion Troubleshoot
Re: Dimming Expansion Troubleshoot
I noticed it yesterday evening when I was sitting there watching it during the LED ramping down. The strange part about it was it wasn't consistently doing it with each % ramping down. It would do it every so often and I noticed after it did it the LED % dim would be less after the RA rebooted.
Then I thought it had something to do with me swapping the jumpers from Analog to PWM, so I switched it back and it did the same thing.
Then I thought it had something to do with the RA unit itself and unplugged the dimming module, but then it didn't have any problems. So I know it has something to do with the dimming module.
Somethings definitely wierd. What about with dimming module connect but lights unhooked?
Are you suggesting to unplug the lights and see if it still does that?lnevo wrote:Somethings definitely wierd. What about with dimming module connect but lights unhooked?
Ok, so I been monitoring it as it ramps up for about an hour and it doesn't happen during the ramp up so far. Is there something wrong with it ramping down?
Yes that was my suggestion. Should be no reason to crash when ramping down.
Ok. It didn't do it when I unplugged the units. So, I'm going to try a different jumper setting since the 0-10v analog was clearly not correct, tried the 0-10v PWM, and had the issue as well, so I guess tonight I will try 0-5v PWM.
Also, is there anyway to do the parabola to start and end at 7% but go to 0% immediately after to avoid the flickering of the lights?
I take that back. Tried again tonight with lights unplugged since even under the 0-5v it was doing it. I don't know why it's tripping it like that, but I think I got a defective unit.
Also, I tested with the current code and unplugged the dimming module and it didn't happen. So it's something to do with the dimming expansion module, considering the jumpers clearly aren't correct.
Roberto?? Any suggestions or send back for a replacement?
rimai wrote:That's what it is looking like.
PM me for RMA.
Hi Roberto,
Sent you a PM. Also, I did some more testing last night. I notice it happens when there are multiple channels being dimmed at once. I dimmed each channel separately and this reset of the relay doesn't happen.
Ok after over a month from my initial purchase (7/22) - i get a replacement unit that seems to be working ok (on 9/3). I say ok because again the jumpers are reversed... (I'm assuming there is very little QC when it comes to RA at this point), whatever - quick work around. Second - last two nights was the first time since I got it hooked up on 9/4 to sit around and see if any problems. Again - this time it doesn't trigger my entire relay box to reset but only outlet #3 during the down ramp of the lights. So I unplug my light from #3 and move it to an always on outlet (not on the relay). Also, it doesn't trigger outlet #3 to reset frequently - it happened only once at around 9pm both nights.
Overall a huge disappointment in spending over $100 on this dimming module and taking over a month, costing me shipping twice (initial and 2nd time), to only have a semi-good working unit. Very worried about the longevity of the dimming module since its already having this issue w/ relay #3.
