help with coding my new toys
goisles1
Post by goisles1 »
Hi,
I have a Avast Swabbie and Skimmate Locker that I need to program
I need the following:
ATO Low port #1 for my ATO pump
ATO HIGH port #3 for my Locker to shut off Skimmer when Locker is full
Swabbie port #4 to run every 5 hours for 180mins
Any advice on how to do this? Can it be achieved using the Wizard? I know there is a dosing option I can most likely use for the Swabbie.
But, Once I program ATO Low on Port 1, it's greyed out for all the other ports in the wizard.
Rob
Re: help with coding my new toys
ReefAngel.Relay.Set(Port3, ReefAngel.ATOHigh.IsActive()) ;
Try this for your high ATO port and skimmer.
The swabbie, do you want it on for 3 hrs and off for 2 hrs? Is that the schedule?
goisles1
Post by goisles1 »
Thanks Roberto. I will try that for the skimmer
For the Swabbie, that was a typo.. meant to say secs not mins.
I want it to run for 3 mins every 5 hours.
So I gave it a shot.. Skimmer is actually on port 2 not 3.
Here is the new code.. does it look ok?
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.SingleATO( true,Port1,1200,0 );
    ReefAngel.Relay.Set(Port2, ReefAngel.ATOHigh.IsActive()) ;
    ReefAngel.Relay.DelayedOn( Port2,30 );
    ReefAngel.Relay.DelayedOn( Port3,30 );
    ReefAngel.StandardLights( Port4,11,45,19,45 );
    ReefAngel.StandardHeater( Port5,771,792 );
    ReefAngel.DosingPumpRepeat( Port7,0,60,180 );
    ReefAngel.StandardHeater( Port8,771,792 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,18,30,0,30,60,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,19,30,0,60,60,0) );
    ReefAngel.Portal( "goisles1" );
I don't think it will work the way it is now, because you are using the delayedon on port 2 also.
You need to change both lines to this:
if (ReefAngel.ATOHigh.IsActive())
  ReefAngel.Relay.Off( Port2 );
Then, add this for your swabbie:
ReefAngel.Relay.Set(Port4, now()%18000<180 );
carlii
Post by carlii »
Just for everyone else who has this setup: ATOHigh was inverted. It should be HighATO
carlii
Post by carlii »
How do I code the portal to alert me when the HighATO switch is off? I tried 0 but I don't get alerts.
Did you wait long enough for the controller to send data to portal?
carlii
Post by carlii »
I get an alert if I set the portal accordingly. "ATO High Port < 255"
What are the possible values for ATO High Port?
Now that I think of it, it may not work :(
The portal doesn't save zeros.
You may need to set a custom variable set as opposite to float switch.
ReefAngel.CustomVar[0]=!ReefAngel.HighATO.IsActive();
carlii
Post by carlii »
I got this response while I had the portal set to notify on High ATO.
Forum ID: carlii
Current Value: 0
ATO High Port < 255
Skimmate Locker Full
Does this mean that a value of "0" is possible.
carlii
Post by carlii »
All is well. ATO High = 0 worked. Thanks.
