Freakin WiFi
Re: Freakin WiFi
When I logged in this time I had a weird thing happen, the "Reef Angel Reef Angel wifi address:" was incorrectly loaded???? I had to change in my profile and it worked after fixing.
Re: Freakin WiFi
Now Portal is really Fubar?? All my modules are not showing in dashboard and everything is OFF or 0.
Re: Freakin WiFi
Do you know the internal ip address of your controller?
Can you browse to http://ipaddress:2000/r99
What does it return back?
Re: Freakin WiFi
Yes port forward and everything works:
192.168.1.3:(Forwarded Port) 2006
Re: Freakin WiFi
Not at home right now. At work
Re: Freakin WiFi
If i Browse this: (external IP):2006/r66
With this message:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
With this message:
<RA><ID>Paul_Velasco</ID><T1>834</T1><T2>820</T2><T3>822</T3><PH>803</PH><R>191</R><RON>0</RON><ROFF>255</ROFF><R1>17</R1><RON1>0</RON1><ROFF1>255</ROFF1><R2>0</R2><RON2>0</RON2><ROFF2>255</ROFF2><R3>0</R3><RON3>0</RON3><ROFF3>255</ROFF3><R4>0</R4><RON4>0</RON4><ROFF4>255</ROFF4><R5>0</R5><RON5>0</RON5><ROFF5>255</ROFF5><R6>0</R6><RON6>0</RON6><ROFF6>255</ROFF6><R7>0</R7><RON7>0</RON7><ROFF7>255</ROFF7><R8>0</R8><RON8>0</RON8><ROFF8>255</ROFF8><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>138</EM><EM1>2</EM1><REM>3</REM><BID>1</BID><AF>0</AF><SF>0</SF><PWMA>59</PWMA><PWMD>59</PWMD><PWMAO>255</PWMAO><PWMDO>255</PWMDO><SAL>126</SAL><WL>0</WL><WL1>20</WL1><WL2>54</WL2><WL3>25</WL3><WL4>49</WL4><DCM>0</DCM><DCS>50</DCS><DCD>50</DCD><DCT>0</DCT><RFM>4</RFM><RFS>100</RFS><RFD>10</RFD><RFW>0</RFW><RFRB>0</RFRB><RFR>0</RFR><RFG>0</RFG><RFB>0</RFB><RFI>0</RFI><RFWO>255</RFWO><RFRBO>255</RFRBO><RFRO>255</RFRO><RFGO>255</RFGO><RFBO>255</RFBO><RFIO>255</RFIO></RA>
Re: Freakin WiFi
Ok, so everything looks correct in there.
I wonder if your wifi attachment is not configured right.
Can you try configuring it again with tera term macro?
http://forum.reefangel.com/viewtopic.php?f=3&t=4601
Re: Freakin WiFi
ok will try
What is the correct baud rate for the port?
Re: Freakin WiFi
here you go:
h1>Bad Request (Invalid Verb)</h1>HTTP/1.1 400 Bad Request
Content-Type: text/html
Date: Wed, 07 Oct 2015 22:40:19 GMT
Connection: close
Content-Length: 35
<h1>Bad Request (Invalid Verb)</h1>HTTP/1.1 400 Bad Request
Connection: close
Content-Length: 35
Connection: close
Content-Length: 35
Connection: close
Content-Length: 35
Re: Freakin WiFi
<<<sendln>>> 'set c r 0'
Got this
What am I doing wrong?
Set Port to 57600
Set Serial Port in Tera Term to 57600
Change SSID
Change PW
Run Macro?
Got this
Set Port to 57600
Change SSID
Change PW
Run Macro?
Re: Freakin WiFi
This is the tera term return (xxx is to keep my info private)
CMD
factory RESET
Set Factory Defaults
<4.00> reboot
*Reboot*CMD
set ftp address 198.175.253.161
AOK
<4.00> save
Storing in config
<4.00> set wlan ssid xxxxxx
AOK
<4.00> set wlan pass xxxxxx
AOK
<4.00> set option deviceid ReefAngelWifi
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
<4.00> set dns name www.reefangel.com
AOK
<4.00> set i h 198.171.134.6
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> GET /r99 HTTP/1.1
Host: 97.xxx.xxx.xxx:2006
Date: Wed, 07 Oct 2015 22:50:08 GMT
Re: Freakin WiFi
Please help now it does not connect to anythin:
CMD
factory RESET
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
<4.00> set wlan ssid NETGEAR42
AOK
<4.00> set wlan pass fearlessapple006
AOK
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
<4.00> set u b 57600
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*GET /r99 HTTP/1.1
GET /r99 HTTP/1.1
Date: Wed, 07 Oct 2015 23:00:45 GMT
Connection: close
Content-Length: 35
Re: Freakin WiFi
Huh go figure it started working even with those errors?
The WebChart is not updating automatically but I can live with that.
Re: Freakin WiFi
Your banner is working. I would think you just need to wait for more data before the web chart updates again. You should be fine now if you check it.
Re: Freakin WiFi
Roberto Thanks for the help!! I almost gave up last night.
Still not sure about the errors. My error logs are filling up.
Re: Freakin WiFi
The error you were getting seemed like you had a client trying to connect to your controller.
Do you have the client suite software trying to pull data?
Re: Freakin WiFi
Yes! Can not run Client Suite and Portal at same time?
Re: Freakin WiFi
You can, but when programming, you need to turn it off or you get errors like you were seeing. The client suite was trying to access the wifi while you were programming and messing with your programming
Re: Freakin WiFi
Paul,
What router are you using? Did you fully solve your issue?
Ever since I got Brighthouse I completely lost my connectivity. Port fowarding doesn't work for my RA, and I also get intermittent connection.
edit:mhmm...my webbanner seems to update but I have no access in the portal.
