No, the connection only lasts a fraction of a second. There is no time for you to see a solid green.
Only if you connect using telnet and deactivate the idle timer should you see a solid green.
WiFi adapter stopped working. I think???
Re: WiFi adapter stopped working. I think???
Ok. So it should be blinking?
Cool. It stayed working last night and has been fine today.
Now I need to figure out why it's not working externally.
Portfowarding is setup and port 2000 is open.
I would ask you to check the DDNS to see if you can see traffic, but it doesn't even come through with the external IP address.
