wifi setup with windows 10
Does the wifi utility work with windows 10? I tried to use it today and couldnt even get the com port to come up.
Re: wifi setup with windows 10
It should work.
Maybe the drivers didn't get installed correctly.
Are you able to upload codes to RA?
Apparently I'm just an idiot..figured out I need to connect the usb to the computer before opening up the wifi utility.
