Moonlights flashing at 0%
Re: Moonlights flashing at 0%
Post your code.
If you connect the moonlight module directly to the dimming channel, does it do the same thing?
Yes, that's where it's at now.rimai wrote:If you connect the moonlight module directly to the dimming channel, does it do the same thing?
I've played around and tried it on the dimming expansion, the same thing happens.
I closed my PC before saving the recent code, I'll see if I can re-produce the code I used
