Can't setup wifi adapter
Re: Can't setup wifi adapter
Both of the blue and green lights do blink. I'll double check the code. I switched computers because I was having issues on the mac, but I dont remember reading anywhere in the manual about the code. I was thinking you had to connect first before you could even upload the code.
You don't need to code it. To program the WiFi attachment, you use the WiFi utility.
It will ask you which com port to use. Make sure to use the same one that you program your RA.
So the RA and the wifi adapter need to be setup on the same computer? I originally setup the RA on my Mac but the Mac couldnt read the wifi adapter so I am trying to use a PC now.
You don't need to setup them both in the same computer.
Just make sure to pick the correct com port.
How many do you have listed?
I have 2. I have COM4 and COM5.
I guess the easiest way if you don't know which one it is, it's to try one and if it doesn't work, try the next.
lol. true. Well while im snowed in I might try and figure it out again.
