Diy Jebao Harness
Re: Diy Jebao Harness
Good move. Save some money and just buy the cables. Probably cheaper in the long run
Lol yea gotta quit when I can . My job moved out of state and was going with but could not afford the difference in cost of living and now laid off and unemployment is only 1/3 my pay lol. But when I get nother job I'm going for it
Is there a way to know aside from a sticker for if my relay box Is anolog or pmw internals or outside build features besides a stickerlnevo wrote:You probably have pwm. The analog should have a sticker on the relay box.
You'd have to open it up and see. Roberto can give you details what you're looking for.
Idk if I should worry about it I see no sticker and any way cable works ether way right
Did u get my FB pm about my dimming expansion I opened it and the red wire looks odd
Yes. I wouldn't worry about it. And yes the cable works with either. Most likely you'd know if the relay box were analog. They cost more so your seller would have said something.
Ok made my cable. Now seems like the pumps have no operation under 17% so how do I add a limit to the dc pump code to not allow pwm 4 and 5 (which is 5v anolog with the jumpers) to not fall past 19% bout not sure if it wI'll effect my feeding and wc mode to 0%/off
First of all the Jwabo pump are 0=10v not 0-5v.
Secondly I haven't seen one go below 25%.
My WP 40 has a lower limit of 30% and my WP 25 had a lower limit of 25%
lnevo helped me with a lot of my coding, but I don't think I have a lower limit set.
I think I get set it so the variation would not go be low 30%.
Feedings and WC they go to 0 and come back fine.
At night I have them set to a constant 30%
I got the app to set it lol I missed that . It's working great on 0-5v . The harness they make have voltage dividers in them to drop 0-10v in half to 0-5v is what I got from bunch of diy cables all 0-10v diy treads had risistors in them to be voltage dividers
Sacohen wrote:First of all the Jwabo pump are 0=10v not 0-5v.
Water change and feed works fine as is found the minimal threshold 20% on 0-5v and I'm going to test the stock jebao controller to see what it really puts out
Wel looks like first of all The rw pumps take a 100% 0-5v anolog signal and a main source ov 24v not 0-10v . Just checked the stock controllerSacohen wrote:First of all the Jwabo pump are 0=10v not 0-5v.
