Dimming bleed over
Lionfan
Dimming bleed over
Post by Lionfan »
Today I noticed that my lights are flickering on one channel.
And it's in sequence with my wavemaker.
And a few times when I manually adjust it to "0" it will do the complete opposite and go to 100.
My lights are CT lites, 0-5 V PWM.
Re: Dimming bleed over
Are you having issues with bus lock?
Lionfan
Post by Lionfan »
rimai wrote:Are you having issues with bus lock?
I was at one point, but I removed my labels from the code and haven't had a bus lock since.
Is the wavemaker on the same dimming module?
Can you post the code?
Lionfan
Post by Lionfan »
rimai wrote:Is the wavemaker on the same dimming module?
yes, its on the same expansion.
Here's the current code
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port5Bit;
    ReefAngel.LightsOnPorts = Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardHeater( Port3,780,785 );
    ReefAngel.StandardFan( Port4,785,790 );
    ReefAngel.StandardLights( Port5,22,0,6,0 );
    ReefAngel.Relay.DelayedOn( Port6,1 );
    ReefAngel.WaterLevelATO( Port7,60,90,100 );
    ReefAngel.StandardLights( Box1_Port1,8,0,20,0 );
    ReefAngel.StandardLights( Box1_Port2,12,0,18,0 );
    ReefAngel.DosingPumpRepeat( Box1_Port3,0,30,240 );
    ReefAngel.DosingPumpRepeat( Box1_Port4,30,30,240 );
    ReefAngel.StandardLights( Box1_Port8,9,0,19,0 );
    ReefAngel.PWM.SetDaylight( PWMParabola(6,0,22,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(7,0,22,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(7,0,22,0,0,75,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(10,0,18,0,0,65,120,0) );
    ReefAngel.AI.SetChannel( White, PWMParabola(11,0,18,0,0,75,0) );
    ReefAngel.AI.SetChannel( Blue, PWMParabola(8,0,21,0,1,100,1) );
    ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(8,0,22,0,1,100,1) );
    ReefAngel.DCPump.SetMode( Else,50,10 );
    ReefAngel.DCPump.ExpansionChannel[3] = Sync;
    ReefAngel.DCPump.ExpansionChannel[4] = AntiSync;
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
ReefAngel.Relay.Override(Port6,0);
    ReefAngel.Portal( "lionfan" );
Lionfan
Post by Lionfan »
Today I noticed alot of blinking, and the strangest thing ;
When I put the app on 0, the dimming expansion would spit out 10 volts.
When it was on 100, it spit out 0 volts. It did this until I unplugged it for a few minutes, and reset everything.
Could it be something with the DCPump and the PWM classes somehow messing with each other.
I'm confident that is not the case, but would you mind testing it be sure?
Remove the DCPump class and set the channel 3, 4 and 5 using the PWM class instead.
If you need help with the code, let me know what mode you would like to set for those channels.
You won't be able to change modes for this test though.
Lionfan
Post by Lionfan »
rimai wrote:Could it be something with the DCPump and the PWM classes somehow messing with each other.
Tried it. No real luck.
Still getting random blinking
Lionfan
Post by Lionfan »
I've changed all of the classes to PWM, and even changed the dimming expansion out (a friend of mine let me borrow his)
Still getting blinking, and lights cutting off.
Weird.
Is it connected directly to the relay box or through a hub?
Can you try directly to the relay?
If you still get the same problem, does it happen the same if you remove the code for the pumps?
Lionfan
Post by Lionfan »
rimai wrote:Weird.
I'll try both tonight.
Im thinking it might be a hub issue.
Im getting some random power clicks on the Reef Angel .
I actually replaced this hub about 3 months ago, so its a stretch that its messed up.
Lionfan
Post by Lionfan »
Lionfan wrote:
rimai wrote:Weird.
The problem seems to go away when I plug up the dimming expansion directly to the relay.
This is really troubling because I just replaced the expansion hub a few months ago.
Do you have anything else connected to the hub?
Are you using the original USB cables?
Check for bad connection and try a different port in the hub.
Lionfan
Post by Lionfan »
rimai wrote:Do you have anything else connected to the hub?
They are the original, although I wouldn't be surprised if they were the problem.
I have a relay expansion, a lunar hub, the dimming expansion, water level expansion, and the WiFi attachment hooked up.
I do get random power flicks time and time again, and even when my lunar hub is on 0, I still get a very dim light.
Random ATO timeouts happen, for no reason, but the controller continues to keep the tank topped off.
I think that's pretty much all my problems. Even with different codes, all this happens.
I think there is one module that is misbehaving and causing a bus lock. That's what would cause the dimming flickers and the relay clicks.
I would start with only one module connected and watching. Then add one at a time to find out which one it is.
Lionfan
Post by Lionfan »
rimai wrote:I think there is one module that is misbehaving and causing a bus lock. That's what would cause the dimming flickers and the relay clicks.
I left my relay expansion unplugged for a few hours today, and that seems to have fixed it. I plugged it back in and still no problems.
I think it's the culprit.
