I'll try both tonight.rimai wrote:Weird.
Is it connected directly to the relay box or through a hub?
Can you try directly to the relay?
If you still get the same problem, does it happen the same if you remove the code for the pumps?
Im thinking it might be a hub issue.
Im getting some random power clicks on the Reef Angel .
I actually replaced this hub about 3 months ago, so its a stretch that its messed up.
