Water level expansion max tubing length
Ismaclst
Post by Ismaclst »
I plan on moving my sump in the basement right below my tank. Right now I have a pvc pipe in my overflow for the water level expansion. Would it still work if I ran the 1/4" tubing from the overflow into the basement? It should be no more then 10 feet long.
Re: Water level expansion max tubing length
I think so. You would need to recalibrate
Ismaclst
Post by Ismaclst »
Ok, thanks.
