unable to setup wifi attachment
djbm3
Post by djbm3 »
I have been trying for over a week on this with no luck. I have two Win7 machines that I have been trying to setup the wifi attachment with. I am unable to communicate with the usb cable over the wifi utility and get a error serial message and I tried using putty but never got a connection.
What are my other options?
Blend-FM.com Faded Friday's every Friday night at: https://www.stream.me/BlendFM
Re: unable to setup wifi attachment
Can you post the message you are getting on both wifi utility and putty?
djbm3
Post by djbm3 »
I had much better luck today working off another machine. I now have a blinking green light and the client says trying to connect to your router...
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 88548 3 wifly-GSX-441-r1057
< 5 74684 3 web_app-GSX-112
< 8 46812 3 wps_app-GSX-131
< 10 66749 3 eap_app-GSX-105
< 12 51053 0 web_config.html
< 25 512 0 link.html
< 28 1052 10 config
< 29 1052 10 user
< 164 Free, Boot=2, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Geaux
< set w s Geaux
< AOK
< <4.41>
> set w p www.aaaa
< set w p www.aaaa
< AOK
< <4.41>
< set w k 00000000000000000000000000
< AOK
< <4.41>
> set ftp address 198.175.253.161
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Geaux
< Chan=1
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=453596
< Boot=2240
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=10.0.0.58:2000
< NM=255.255.255.0
< GW=10.0.0.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
That looks like it is up and running now.
The ip address reported is 10.0.0.58.
You should be good to go.
djbm3
Post by djbm3 »
Thank you for the help Rob.
I have everything setup and got my DNS setup and I can connect to my device while on my network but I cannot connect from an external network. I can see that port 2000 is open but I did not configure the dns update information into my router and maybe that is the issue. I will try to get it connected more this weekend.
What router changes are necessary for this traffic?
You need to setup port forwarding on your router.
