2 RAs on same network
Re: 2 RAs on same network
alright, I think I was able to get the port changed, but that doesn't help. i set up the port forward just like the first RA, but when i go to canyouseeme, it says Connection Timeout. also, I noticed the portal is displaying the RA on port 2000, instead of port 2020.
Still nothing todayrimai wrote:Did you try on 57600 baud rate?
I did. I set the ip localport to 2010, and then again to 2020. Still no cigarrimai wrote:You have to type $$$ within a second. So, type it fast.
Ahh. I thought you were not being able to even enter command mode.
Did you issue command save and reboot after you changed it?
Can you explain exactly what you cannot do?
I think I see what's going on.
Even tho I set up port forwarding, my router is still refusing connection to port 2010.
I'm still using my stock Xfinity Gateway.
And it sucks. Even tho I've set up port forwarding and DMZ, I don't think it can handle having two ports open so close together.
I'm pulling my cisco router out of the attic tomorrow and using it instead.
It has better settings and features.
