Portal Settings, Water Leak Flag?
Re: Portal Settings, Water Leak Flag?
Multi channel, but I'm pretty sure I had premature ato timeouts when i was using the singleato. I'm using memory but I'm pretty sure Im passing most arguments in as if it were hard coded because I'm spoofing my low level. (Memory has 20%-80%, but I'm calling it as 79-80%)
Sorry for the late response, life has been busy!
Yes, there's a spot in the alerts page on the main display unit.
I know there is a page for the alerts, but is the water leak in there?
Also, in the page where you have the ATO, it should also show the status of the leak detector expansion.
Did you add the code to enable it?
On the alerts page, does it signal the leak is active? (change color or such?) Apologies I have it unplugged atm for rearranging..
For the code to enable it, I used the wizard and selected the checkbox, where do I verify it's enabled?
