does anyone think there would be a way to connect this to the reefangel?
https://www.adafruit.com/products/1786
water level sensor
Re: water level sensor
Have you checked out the Reef Angel water level expansion module?
http://www.reefangel.com/QuickViewWater ... nsion.html
To be honest, my original plan was to use eTape.
I worked with the manufacturer, but was never able to get a good response from the tape and I never found a way to get a water tight connection to it to protect the end connector.
So, I decided to go with pressure sensitive sensor to monitor the water level and it works much better in my opinion.
ahh ok.. I did see that. what im looking to do is make a dosing container that is compatible to the DOS system from apex. I have finally gotten my cnc router up an calibrated to start trying to make things like that. the tape sensor seemed like a good fit.
A cool RA compatible dosing container would be sweet. You could eliminate the stock RA pipe and adapter if you can provide an airtight column and an airline connector. That'd be sweet! If you can make it the right size I'd buy some
I will look into that. instead of the 1/2" pipe could I use a 1/4 or 3/8 inch rigid tubing?lnevo wrote:A cool RA compatible dosing container would be sweet. You could eliminate the stock RA pipe and adapter if you can provide an airtight column and an airline connector. That'd be sweet! If you can make it the right size I'd buy some
lol awesome! a reason to work harder on it!
im going to start working on this next week hopefully. what size does the connector need to be for the tubing to connect to the sensor? is it standard 1/4 airline tubing?
