Wifi not working today
jjdezek
Post by jjdezek »
Not sure what's going on but I can't connect to my reef angel from the app. I tried unplugging the wireless adapter from the reef angel and unplugged my modem still getting the unable to process controller data. Usually I can just unplug and reconnect and it starts working again but not this time. It has the one blinking green light. I'm trying to do a water change but I'm unable to turn relays on or off for my mixing pump.
Re: Wifi not working today
If it is just blinking green, it is connected to your WiFi network.
Check on the router. It may have changed the ip address.
jjdezek
Post by jjdezek »
I can get through the portal just not the app.
jjdezek
Post by jjdezek »
Why would I be able to access it through the web portal but not the app? I I can pull up the web portal and toggle things on and off yet when I pull up the app it won't load. I haven't changed anything on either the app or the portal.
jjdezek
Post by jjdezek »
Ok figured it out. Had use a different IP address. Looked at the one on the portal and plugged that in and it started working. Not sure why it changed I had it set up as a web address type IP address.
