Wifi flashing blue
jjdezek
Wifi flashing blue
Post by jjdezek »
My wifi has been working fine. Left the house and had a thunderstorm roll through, came home to wifi flashing blue. I unplugged it and plugged it back in but still flashing blue. Do I need to reprogram it? What would cause it to start flashing blue? Everything else is connected to wifi in my house except my reefangel.
jjdezek
Re: Wifi flashing blue
Post by jjdezek »
Well now it's back to flashing green but I still can't access it from the app but the portal works.
ip changed?
jjdezek
Post by jjdezek »
The IP address I used is the one showing on the portal. Is that not the correct IP
Your internal ip may have changed and you would need to reconfigure your port forwarding.
jjdezek
Post by jjdezek »
Figured it out. I had to delete the file in the app and start a new controller file and it started working. IP address stayed the same so not sure what happened or what caused it.
