Wifi - reinitialise
PostPosted: Sat Jul 30, 2016 6:41 am
Hi all,
I'm overseas for an 8 week trip. We've been away for 2 weeks and my RA has fallen offline.
I got my house sitter to reboot routers/wifi etc but the RA wifi module hasn't reconnected...
What's the simplest way I can get the house sitter to reinit the wifi? would an RA reboot work? or even a power cycle from the wall?
Suggestions?
PostPosted: Sat Jul 30, 2016 3:23 pm
Power cycle probably the easiest. Could also unplug and replug the wifi module.
PostPosted: Sat Jul 30, 2016 3:24 pm
Roberto, is it possible to send a reboot to the wifi from the controller we could add a menu or automate it say once per day if someone wanted
PostPosted: Sat Jul 30, 2016 11:02 pm
Send $$$ then send reboot/n
I think this should do it.
It's just like when you set it up with putty.
PostPosted: Sun Jul 31, 2016 5:27 am
So technically it's even possible to configure the module from the RA? Like if we had ReefAngel.WiFi.SSID("ssid", "key"); ?
PostPosted: Mon Nov 20, 2017 5:53 pm
rimai wrote:Send $$$ then send reboot/n
hi there. Sorry to bring this up.. iveno once asked If It is possible to reboot the wifi module from the RA and Roberto just answered the above.
What is the C++ command to send the $$$ and the Reboot/n?
Is it really possible to reboot the wifi module from RA?
Recentelly my wifi module keep loosing connection and give me a blinking blue led. Have to unplug the module from the RA+ or unplug everything from the wall... It would be nice to be able to reboot the wifi module from time to time...
That's what is happening
[youtube]https://youtu.be/4nU7BM2rFbA[/youtube]
Rafa
PostPosted: Tue Nov 21, 2017 8:48 am
Hi
Found this other thread
viewtopic.php?f=3&t=2449&p=19989&hilit=Do+you+have+any+software+pulling+data+from+RA#p19989
  if (millis()%3600000<500)
    Serial.print("$$$");
    wdt_reset();
    delay(700);
    wdt_reset();
    Serial.println("reboot");
Is that it? This code reboots the Wifi module?
Best Regards
Rafa
PostPosted: Tue Nov 21, 2017 10:54 am
it is worth trying
PostPosted: Tue Nov 21, 2017 11:35 am
Hi Roberto
I will try both Serial.println("reboot"); and Serial.println("reboot/n"); and post the results.
Did you have the chance to watch https://youtu.be/4nU7BM2rFbA ?
Best regards
Rafa
PostPosted: Wed Nov 22, 2017 5:29 pm
Hi Roberto
Upload this code and worked just fine:
    wdt_reset();
    delay(700);
    wdt_reset();
It reinitialises the wifi module. I still don't know what makes it act like this https://youtu.be/4nU7BM2rFbA though.
Return to Addons
