Wifi - reinitialise
Posted: Sat Jul 30, 2016 6:41 am
by soyrex
Hi all,
I'm overseas for an 8 week trip. We've been away for 2 weeks and my RA has fallen offline.
I got my house sitter to reboot routers/wifi etc but the RA wifi module hasn't reconnected...
What's the simplest way I can get the house sitter to reinit the wifi? would an RA reboot work? or even a power cycle from the wall?
Suggestions?
Re: Wifi - reinitialise
Posted: Sat Jul 30, 2016 3:23 pm
Power cycle probably the easiest. Could also unplug and replug the wifi module.
Posted: Sat Jul 30, 2016 3:24 pm
Roberto, is it possible to send a reboot to the wifi from the controller we could add a menu or automate it say once per day if someone wanted
Posted: Sat Jul 30, 2016 11:02 pm
Send $$$ then send reboot/n
I think this should do it.
It's just like when you set it up with putty.
Posted: Sun Jul 31, 2016 5:27 am
So technically it's even possible to configure the module from the RA? Like if we had ReefAngel.WiFi.SSID("ssid", "key"); ?
Posted: Mon Nov 20, 2017 5:53 pm
by rrodriguess
rimai wrote:Send $$$ then send reboot/n
hi there. Sorry to bring this up.. iveno once asked If It is possible to reboot the wifi module from the RA and Roberto just answered the above.
What is the C++ command to send the $$$ and the Reboot/n?
Is it really possible to reboot the wifi module from RA?
Recentelly my wifi module keep loosing connection and give me a blinking blue led. Have to unplug the module from the RA+ or unplug everything from the wall... It would be nice to be able to reboot the wifi module from time to time...
That's what is happening
[youtube]
https://youtu.be/4nU7BM2rFbA[/youtube]
Rafa
Posted: Tue Nov 21, 2017 8:48 am
by rrodriguess
Hi
Found this other thread
http://forum.reefangel.com/viewtopic.ph ... +RA#p19989
if (millis()%3600000<500)
Serial.print("$$$");
wdt_reset();
delay(700);
wdt_reset();
Serial.println("reboot");
Is that it? This code reboots the Wifi module?
Best Regards
Rafa
Posted: Tue Nov 21, 2017 10:54 am
it is worth trying
Posted: Tue Nov 21, 2017 11:35 am
by rrodriguess
Hi Roberto
I will try both Serial.println("reboot"); and Serial.println("reboot/n"); and post the results.
Did you have the chance to watch
https://youtu.be/4nU7BM2rFbA ?
Best regards
Rafa
Posted: Wed Nov 22, 2017 5:29 pm
by rrodriguess
Hi Roberto
Upload this code and worked just fine:
wdt_reset();
delay(700);
wdt_reset();
It reinitialises the wifi module. I still don't know what makes it act like this
https://youtu.be/4nU7BM2rFbA though.
