wifi adapter acting strange
tech9
Post by tech9 »
I can connect via the portal, and also by aquarium log (sometimes) but I cannot connect to the RA directly using http://IP:2000/wifi it just brings up a blank page, but IP:2000 brings up: Reef Angel Controller Web Server, also IP:2000/sa works but only sometimes. Should I try and upgrade the firmware on the wifi?
Also on a side note: any EASY way to change the PWM dimming on the fly, like if I want blues at 100% while I work on the tank, but just an override that will revert if I change it back. I was logging into the wifi RA direct, but its kind of a pain.
I can PM my ip if you want to test it.
-Joe
Re: wifi adapter acting strange
You can set the pwm overrides to a value 0-100. Anything above cancels the override. Take a look at the thread wifi attachment commands (think its in the portal forum)
Its something like this /pwmao100 to set the actinic channel to 100.
As far as the rest the /wifi relies on external files. Maybe the site is blocked where your testing? Either way I'd say check your port forwarding
tech9
Post by tech9 »
So maybe my files on RA are just corrupt:
Why do I get this also:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM5
< CMD
< GET /r99 HTTP/1.1
< Host: 192.168.88.189:2000
> reboot
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM5
< CMD
> ftp u
< ftp u
< <4.41>
< FTP connecting to 198.175.253.161
< FTP file=27:...GET /r99 HTTP/1.1
< ....................GET /r99 HTTP/1.1
< UPDATE OK
< FTP OK.
> ftp r wps.img
< HTTP/1.1 400 Bad Request
< Content-Type: text/html
< Date: Wed, 31 Aug 2016 00:56:21 GMT
< Connection: close
< Content-Length: 20
You have something trying to connect to the module.
Most likely the client suite.
I would recommend stopping it before you try to perform any update or it will keep interrupting it.
tech9
Post by tech9 »
Actually yes, I just discovered that, i couldn't figure out what was doing that. Still not updating for some reason. I did a factory reset on the wifi module, and re-setup and even tried the TeraTerm "fix" you posted.
But I reloaded the RA to factory, uploaded my wizard code, its working 100%, except the wifi dashboard
It goes to the "Reef Angel Controller Web Server" just fine, but blank page on the /wifi, tried on different computers, my phone, etc. Where are those files stored that it cannot access. Also I am connecting locally when trying this: http://192.168.88.189:2000/wifi It all started after a power outage.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
< DHCP in 2143ms, lease=600s
< IF=UP
< DHCP=ON
< IP=192.168.88.189:2000
< NM=255.255.255.0
< GW=192.168.88.1
< Listen on 2000
> ftp u
< ftp u
< <4.41>
< FTP file=25:................................................................
< UPDATE OK
< FTP OK.
> ftp r wps.img
< ftp r wps.img
< <4.41>
< 550 wps.img: The system cannot find the file specified.
< FTP ERR
/wifi was not working for anybody.
The reefangel.com server had missing files after I moved hosting provider.
It's fixed now and you should be able to get /wifi again.
