Wifi or app issue?
nevets9333
Wifi or app issue?
Post by nevets9333 »
I have the app on my iphone, and have had no issues for the past year. Now for some reason I cannot see an updated graph when I try to look at the PH/temp. If i refresh the home screen I get real time stats, but if I go to create a graph it won't update past the 20th of Dec. Any idea why I can see updated info but can't graph it? It seems my portal is also not updating past the 20th. Thanks, Steven.
Re: Wifi or app issue?
Try updating the settings on the wifi attachment with this macro:
nevets9333
Thank you. Not too familiar with this kind of stuff so I don't know if I am doing it correctly. When I open tera term, select the serial port, open the updated file with macro I get "start wifly module configuration" and click ok. When I open the wifi utility and hit connect I get "ERROR: Connecting to COM3 and Error inside serial.<init>()"
Only use tera term.
Don't use the WiFi utility.
nevets9333
So after I click OK on the start wifly module configuration what do I do? All I see is a bunch of symbols and numbers appear across the screen.
can you post what you get?
nevets9333
You are not connecting with the correct baud rate. It needs to be 57600
nevets9333
Thank you so much! I truly appreciate your patience and help!
