Wifi or app issue?
Posted: Tue Dec 27, 2016 9:38 am
by nevets9333
I have the app on my iphone, and have had no issues for the past year. Now for some reason I cannot see an updated graph when I try to look at the PH/temp. If i refresh the home screen I get real time stats, but if I go to create a graph it won't update past the 20th of Dec. Any idea why I can see updated info but can't graph it? It seems my portal is also not updating past the 20th. Thanks, Steven.
Re: Wifi or app issue?
Posted: Tue Dec 27, 2016 11:24 am
Try updating the settings on the wifi attachment with this macro:
Posted: Tue Dec 27, 2016 12:13 pm
by nevets9333
Thank you. Not too familiar with this kind of stuff so I don't know if I am doing it correctly. When I open tera term, select the serial port, open the updated file with macro I get "start wifly module configuration" and click ok. When I open the wifi utility and hit connect I get "ERROR: Connecting to COM3 and Error inside serial.<init>()"
Posted: Tue Dec 27, 2016 12:21 pm
Only use tera term.
Don't use the WiFi utility.
Posted: Tue Dec 27, 2016 1:12 pm
by nevets9333
So after I click OK on the start wifly module configuration what do I do? All I see is a bunch of symbols and numbers appear across the screen.
Posted: Tue Dec 27, 2016 1:56 pm
can you post what you get?
Posted: Tue Dec 27, 2016 2:41 pm
by nevets9333
- Capture.PNG (46.07 KiB) Viewed 6642 times
Posted: Tue Dec 27, 2016 4:28 pm
You are not connecting with the correct baud rate. It needs to be 57600
Posted: Tue Dec 27, 2016 4:54 pm
by nevets9333
Thank you so much! I truly appreciate your patience and help!
