Page 2 of 2
Re: Cloud Wifi Attachment
Posted: Wed May 31, 2017 1:42 pm
by slm222
rimai wrote:See if this code makes any difference.
I will add this into my cloud device tonight. Thank you
This is your rewritten code with my info at the bottom i will add
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
//char ssid[32];
//char pass[32];
//char username[16];
//char password[16];
unsigned long client_timeout = millis();
unsigned long wifi_connection = millis();
unsigned long serial_timeout = millis();
unsigned long led_blink = millis();
unsigned long MQTTReconnectmillis = millis();
boolean LED_status = false;
boolean PortalConnection = false;
boolean power_status = true;
boolean data_ready = false;
int status = WL_IDLE_STATUS;
int connection_counter=0;
WiFiServer server(2000);
WiFiClient client;
WiFiClient portalclient;
WiFiClient mqttclient;
void mqttcallback(char* topic, byte* payload, unsigned int length);
PubSubClient CloudClient(MQTTServer, MQTTPORT, mqttcallback, mqttclient);
String currentLine = "";                // make a String to hold incoming data from the client
void setup() {
  Serial.begin(57600);      // initialize serial communication
  Serial1.begin(57600);      // initialize serial communication
  pinMode(5, OUTPUT);      // set the LED pin mode
  pinMode(6, OUTPUT);      // set the LED pin mode
  pinMode(7, OUTPUT);      // set the LED pin mode
  wdt_initialize();
  wdt_enable();
void loop() {
  wdt_reset();
  status = WiFi.status();
  while ( status != WL_CONNECTED) {
    digitalWrite(5, false);
    digitalWrite(6, true);
    digitalWrite(7, false);
    if (millis() - wifi_connection > 1000)
      Serial.print("Attempting to connect to Network named: ");
      Serial.println(WIFI_SSID);                   // print the network name (SSID);
      if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
        server.begin();                           // start the web server on port 2000
        printWifiStatus();                        // you're connected now, so print out the status
        digitalWrite(6, false);
        digitalWrite(7, true);
      Serial.println("Not connected...");
    wdt_reset();
  client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println(F("new incoming client"));           // print a message out the serial port
    while (client.connected()) {            // loop while the client's connected
      if (millis() - client_timeout > 2000) client.stop();
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        Serial1.write(c);                   // send to Reef Angel
      if (Serial1.available())
        char c = Serial1.read();
        //Serial.write(c);
        currentLine += c;
        if (currentLine.length() == 255) {
          SendData();
      if (millis() - serial_timeout > 400)
        if (currentLine.length() > 0) {
          SendData();
          Serial.println();
          client.println();
      if (millis() - led_blink > 50)
        LED_status = !LED_status;
        digitalWrite(6, LED_status);
    // close the connection:
    client.stop();
    Serial.println(F("incoming client disconnected"));
    while (Serial1.available())
      currentLine += c;
      if(c==10) data_ready=true;
      if (millis() - serial_timeout > 200 || data_ready)
          data_ready=false;
          //        Serial.print(currentLine);
          if (currentLine.startsWith("GET"))
            PortalConnection = true;
            Serial.println(F("Connecting to Portal Server"));
            if (portalclient.connect(PortalServer, 80)) {
              Serial.println(F("Connected"));
              // Make a HTTP request:
              portalclient.print(currentLine);
              portalclient.println(F(" HTTP/1.1"));
              portalclient.println(F("Host: forum.reefangel.com"));
              portalclient.println(F("Connection: close"));
              portalclient.println();
              Serial.println(F("Failed to connect"));
          if (currentLine.startsWith("CLOUD:"))
            //Serial.print(currentLine);
            if (currentLine.length() < 32)
              if (CloudClient.connected())
                //Serial.println(F("Publishing "));
                currentLine.replace("CLOUD:", "");
                char pub_buffer[sizeof(CLOUD_USERNAME) + 5];
                sprintf(pub_buffer, "%s/out", CLOUD_USERNAME);
                char pub_msg[currentLine.length() + 1];
                currentLine.toCharArray(pub_msg, currentLine.length() + 1);
                CloudClient.publish(pub_buffer, pub_msg);
              Serial.print(F("Error on incoming data: "));
              Serial.println(currentLine.length());
          currentLine = "";
    while (portalclient.available()) {
      char c = portalclient.read();
      //      Serial.write(c);
    if (PortalConnection && !portalclient.connected()) {
      //      Serial.println();
      Serial.println(F("Disconnecting from Portal Server"));
      portalclient.stop();
  CloudClient.loop();
  if (millis() - MQTTReconnectmillis > 5000)
    if (!CloudClient.connected())
      char sub_buffer[sizeof(CLOUD_USERNAME) + 6];
      Serial.println(F("MQTT Connecting..."));
      Serial.print(F("Attemp: "));
      Serial.println(++connection_counter);
      if (connection_counter>5)
        Serial.println(F("Unable to connect. Rebooting..."));
        digitalWrite(5, true);
        while(1);
      sprintf(sub_buffer, "RA-%s", CLOUD_USERNAME);
      if (CloudClient.connect(sub_buffer, CLOUD_USERNAME, CLOUD_PASSWORD))
        sprintf(sub_buffer, "%s/in/#", CLOUD_USERNAME);
        Serial.println(F("MQTT succeeded"));
        CloudClient.subscribe(sub_buffer);
        Serial.println(F("MQTT failed"));
        CloudClient.disconnect();
  if (analogRead(0) < 600 && power_status)
    power_status = false;
  if (analogRead(0) > 600 && !power_status)
void SendData()
  currentLine = "";
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  Serial1.print("cloud:");
  for (int a=0;a<length;a++)
    Serial1.write(payload[a]);
    Serial.write(payload[a]);
  Serial1.print(" ");
  Serial.println();
void wdt_initialize()
  GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
  GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
                      GCLK_GENCTRL_GENEN |
                      GCLK_GENCTRL_SRC_OSCULP32K |
                      GCLK_GENCTRL_DIVSEL;
  while (GCLK->STATUS.bit.SYNCBUSY);  // Syncronize write to GENCTRL reg.
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
                      GCLK_CLKCTRL_CLKEN |
                      GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
  WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CTRL reg.
  WDT->CONFIG.reg = WDT_CONFIG_PER(0xA);  // 0xA = 8192 ms
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CONFIG reg.
  WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
  WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
  WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX1+McuCAkIlSsRrljZrxqPemQeco0gw3Qh0=
// RA_STRING2=U2FsdGVkX182otKKK42E19GJNzbCmJB4k/bR5D12l+Q=
// RA_STRING3=Monroe
Posted: Wed May 31, 2017 4:53 pm
by MisterTang
This looks really cool - but I'm not seeing a UApp for Android in the store but do see one in the iTunes store. Is there a plan to officially support Android?
Posted: Wed May 31, 2017 5:05 pm
The Uapp should be in the apple store, but it is an outdated version.
It was originally designed to be the Apple app and got migrated to a web based application since it is entirely created as a web application natively.
I can also post on the Android store too.
I'm just waiting to get all the bugs out before I released it on both stores. It's a pain to release to the stores :(
In the mean time, you can use the browser of your phone to make it work.
Posted: Wed May 31, 2017 5:49 pm
by slm222
I have loaded the code and it has been in a state of trying to connect for an hr. constant solid currently. It owuld blink occasionally when i first plugged it in.
Posted: Wed May 31, 2017 5:51 pm
Can you pull log again?
Posted: Wed May 31, 2017 6:02 pm
by slm222
Ok, I tried to pull a log and it would not show a COM port to allow me to select. I disconnected the device and replugged in with my computer and COM showed up, i think plugged into the reef angel and it is working now. I was trying to get back before you had read my inital response as a simple reset fixed it. I will keep monitoring it and report back.
Again Thank you for your promptness, we are soon to travel out of the country and not being able to see the tank was a bit worrying to me.
Posted: Wed May 31, 2017 7:46 pm
by slm222
So something interesting is going on. and it had to do with the sequence of how i plugged the unit it. when i plug the unit into the reef angel it blinks green and goes solid green with an occasional blink, then when i plug into it with the computer to run the serial monitor the computer prompts that the usb was not recognized and disables and re-enables the port and at that point the wifi unit turns blue immediately and stays running. I unplugged the computer and it stayed blue, then after a while (longer than i know as i was not paying attention) the light completely turned off. Then the cycle starts over.
Posted: Thu Jun 01, 2017 11:50 am
by slm222
I re uploaded as well reset the whole system and it is functioning now
Posted: Sun Jun 04, 2017 5:00 pm
by slm222
This is going on with both the old and the new routers. With the modified code below i am getting "Attempting to connect to Network named:
Not connected..." on the serial monitor scrolling over and over. It is staying constant green. With the webwizard code it is connecting to the wifi and upload but only when i have the usb cable plugged into the side and plugged into the computer. as soon as i unplug it changes to teal for a couple seconds and then goes back to solid green and an occansional blink. when i plug the usb back in it states the usb is not recognized and then refreshes the connection itself by diconnecting and reconnecting and at that point it turns blue and acts normal.
*Edit: something interesting i just tried. i plugged the usb cable into the side of the wifi unit and then into the iphone wall charger. it started working with that plugged in as well and the webwizard code.... not sure what to make of that.
#include <SPI.h>
//char ssid[32];
//char pass[32];
WiFiClient client;
void setup() {
  wdt_initialize();
  wdt_enable();
void loop() {
  wdt_reset();
    wdt_reset();
        //Serial.write(c);
        currentLine += c;
          SendData();
          SendData();
          Serial.println();
          client.println();
    client.stop();
      currentLine += c;
          data_ready=false;
          currentLine = "";
      //      Serial.write(c);
  CloudClient.loop();
        while(1);
void SendData()
  currentLine = "";
  Serial.println(ip);
  Serial.print(rssi);
  Serial1.print(" ");
  Serial.println();
void wdt_enable()
void wdt_disable()
void wdt_reset()
// RA_STRING1=U2FsdGVkX1+AF2lnzKYQyNPLiQGZJdj0GFAKsjt2XXk=
// RA_STRING2=U2FsdGVkX1+K7xN24vw/vykDiKano9Ep9ArQL7gfcck=
Posted: Mon Jun 12, 2017 6:09 am
by slm222
Anyone?
Posted: Mon Jun 12, 2017 10:45 am
You mentioned it was working.
Is it not?
Posted: Fri Jun 16, 2017 8:07 am
by slm222
No it's doing as in my second to last post on page 4. It stays green until I plug in the USB into a computer or wall outlet. Then it acts as if it resets itself so I can't serial monitor it. I had left it connected to just the reef angel since the 8th and it stayed connected until the 11th and had been solid green since then as I am out of the country and have a house sitter telling me the color of the light.
Posted: Fri Jun 16, 2017 5:47 pm
If you are getting this: "Attempting to connect to Network named:
Not connected..."
Your code is wrong. It doesn't have the SSID name.
Posted: Sun Jun 18, 2017 5:14 am
by slm222
It does connect and I have verified data going to the U-App. The problem is after a time it goes to green light only, It's acting as if it locks up. My previous posts explain the steps I've taken after it locks up.
Posted: Sun Jun 18, 2017 3:01 pm
How far is it from router?
I wonder if it is loosing the connection.
Posted: Wed Jun 21, 2017 11:25 am
by slm222
It is 10-15' and open air connection. No blockages. In the same room
Posted: Fri Jun 23, 2017 7:26 pm
by slm222
I have been gone to Europe for 2 weeks and upon return it seems to unit is completely dead. Plugging in the USB or the cable to the reef angel. Should I email support?
Posted: Sun Jun 25, 2017 6:34 pm
Yes, send an email to info@reefangel.com
Posted: Sun Aug 13, 2017 10:46 pm
Kungpaoshizi wrote:Can we expect code uploads via the device someday?
I think that's one thing I would really like... Though I have gotten to the point where my reef tank setup is simple enough I don't need to change anything... lol
It seems jeelabs has released a couple months ago an alpha version of a firmware that emulates the stk500v2 that is required to program our microcontrollers :)
https://github.com/jeelabs/esp-link/releases
If someone is interested in investigating and checking if we could use it, let me know.
Posted: Mon Jun 11, 2018 3:47 pm
by 89delta
Am Getting an error trying to compile...I have the latest Dev library.
My_RA_Version_3_0.cpp: In function 'void loop()':
My_RA_Version_3_0:372: error: 'class ReefAngelClass' has no member named 'CloudPortal'
//Sketch Date May 13, 2018
//Version 3.0
#include <SunLocation.h>
#define NUMBERS_8x16
#define PI 3.141593
//#include <RA_PCA9685.h>
//#define I2CPWM_PCA9685      0x40
SunLocation sl;
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
////// Memory Locations used by all formulas
#define Mem_B_AcclDay  100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration  101 // Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart  102 // Set this to your desired starting acclimation end%.
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue  105    // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue  106    // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite  110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite  111    // Slope End%
// Define Portal Variables
#define Var_AcclDay         0  // Days Left in Coral Acclimation
//#define Var_StormMode       1  // Lightning Storm Mode: 0=Slow (For Unresponsive LED Drivers: Meanwell ELN), 1=Fast, 2=Mega
//#define Var_Wmaker       2
//#define Var_Tide         3
//#define Var_TideMode     4
//#define Var_LogATO       5
//#define Var_WCVol        6
#define Var_weekday        7  //Day of the week: 0=Sunday, 1=Monday, 2=Tuesday, 3=Wednsday, 4=Thursday, 5=Friday, 6=Saturday
void DrawCustomMain() {  //5,14
  char buf[16];
  //byte acclDay = InternalMemory.read(Mem_B_AcclDay);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 10, 4, "Paradise Reef");
  ReefAngel.LCD.DrawDate(6, 118);
  // Temp and PH
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,10,65,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,85, 65, "PH:");
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 48, 73, buf);
  ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, 10, 75, buf, Num8x16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 85, 75, buf, Num8x16);
  ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 48, 82, buf);
  //ATO
  /*ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,40,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,40,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_RED);
  //Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,75,93,text);
  //Sunrise/Sunset Times
  //ReefAngel.LCD.DrawText(0,255,5,52,"Rise:");
  //ReefAngel.LCD.DrawText(0,255,38,52,(sl.GetRiseHour()));
  //ReefAngel.LCD.DrawText(0,255,43,52,":");
  //ReefAngel.LCD.DrawText(0,255,48,52,(sl.GetRiseMinute()));
  //ReefAngel.LCD.DrawText(0,255,65,52,"Set:");
  //ReefAngel.LCD.DrawText(0,255,88,52,(sl.GetSetHour()));
  //ReefAngel.LCD.DrawText(0,255,100,52,":");
  //ReefAngel.LCD.DrawText(0,255,105,52,(sl.GetSetMinute()));
  //Moon Phase
  //ReefAngel.LCD.DrawText(0,255,5,72,"Moon:");
  //ReefAngel.LCD.DrawText(0,255,35,72,MoonPhaseLabel());
  // Display Acclimation timer
  //ReefAngel.LCD.DrawText(0,255,5,82,"Acclimation Day:");
  //ReefAngel.LCD.DrawText(0,255,105,82,acclDay);
  // Display LED %
  //ReefAngel.LCD.DrawText(0,255,12,92, "CW:");
  //ReefAngel.LCD.DrawText(197,255,32,92, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.LCD.DrawText(0,255,72,92, "RB:");
  //ReefAngel.LCD.DrawText(3,255,92,92, ReefAngel.PWM.GetActinicValue());
  // Display Relays
  ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
    ReefAngel.LCD.DrawGraph(5, 12);
/*void SeasonalTemps ()
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,800},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.AddSalinityExpansion();
    // Default Salinity compensation
    ReefAngel.Salinity.SetCompensation(0);
    ReefAngel.FeedingModePorts = Port3Bit| Port5Bit | Port6Bit ;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
  //sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
  //sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
    sl.Init(38.8447,-104.8433); // Colorado Springs,CO In decimal numbers (i.e. -18.285833, 147.699722)
    sl.SetOffset(-6,0,-6,0); // rise_hour, rise_seconds, set_hour, set_seconds
  randomSeed(now()/SECS_PER_DAY);
  //if (InternalMemory.read(Mem_B_ResetMemory))
    //init_memory();
        //Temp Code for Fuge Light
    //ReefAngel.StandardLights( Port5,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
    //ReefAngel.StandardLights( Port7,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
    // 15min Delay on Skimmer coming from Feeding oe Waterchange Modes
    ReefAngel.Relay.DelayedOn(Port3, 10);
    // Custom Variable for Portal
    ReefAngel.CustomVar[Var_weekday]=weekday();
    //Heater
    //SeasonalTemps();
    // Jebao Code
    pinMode(lowATOPin,OUTPUT);
    analogWrite(lowATOPin,ReefCrestMode(50,20,true)*2.55);
    ReefAngel.DCPump.LowATOChannel = AntiSync ; // Jebo connected to AtoPINLow
    pinMode(highATOPin,OUTPUT);
    analogWrite(highATOPin,ReefCrestMode(50,20,true)*2.55);
    ReefAngel.DCPump.HighATOChannel = AntiSync ; // Jebo connected to AtoPINLow
    // Add random mode if we set to Mode to Custom in portal
    static int rmode;
    byte modes[] = { Lagoon, ReefCrest, TidalSwell, Sine, Gyre, NutrientTransport, Else };
    if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
    rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
    changeMode=true;
    static unsigned long feeding;
    if (now()-feeding<900) {
      // First 15 minutes after feeding mode stops. Smart_NTM
      ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()-feeding<2250) { // 15 minutes plus 1 hour
      // Continue NTM for the next 60 minutes (75 minutes total)
    } else if (now()%SECS_PER_DAY<23400 || now()%SECS_PER_DAY>=72000) { // 6:30am / 8:00pm
      // Night mode (go to 30%)
      ReefAngel.DCPump.Mode=Constant;
      ReefAngel.DCPump.Speed=32;
      //ReefAngel.DCPump.SetMode(Constant,31,45,30);
    } else if (InternalMemory.DCPumpMode_read()==11) {
      if (modes[rmode]==Else) {
        ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
      } else {
        ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
    } else {
////////// Variables used for all channels
// What day in the acclimation cycle it is
  byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
  byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 3 channels
////////// Blue Channel Variables
  byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue);
// Starting End% for Acclimation cycle
  float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);
// Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
  float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;
// How much your Blue end% rises per acclimation day
  float acclFactorBlue = acclDay * acclPercentPerDayBlue;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentBlue = acclendPercentBlue - acclFactorBlue;
// Your final Blue end% for the day
////////// White Channel Variables
  byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);
  float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);
// Your target White end% once acclimation is complete
////////// White Channel Formula
  float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;
// How much your White end% rises per acclimation day
  float acclFactorWhite = acclDay * acclPercentPerDayWhite;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
ReefAngel.CustomVar[Var_AcclDay]=acclDay;
// At the end of the day, we need to decrement the acclimation counter.
  static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
  if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
  if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
    acclDay--; // Reduce the counter
    acclCounterReady=false; // Reset the boolean flag
    InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
    // handle updating sunrise and sunset values
    sl.CheckAndUpdate();
    //ReefAngel.Portal( "89delta","collin1123" );
    //ReefAngel.DDNS( "bc29" ); // Your DDNS is 89delta-bc29.myreefangel.com
    ReefAngel.CloudPortal();
  // Calculate your regular sunrise/sunset PWM value
  ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentBlue,120,(MoonPhase()/3));
  DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentWhite,120,DaylightPWMValue);
  CheckCloud();
// RA_STRING1=U2FsdGVkX19/CQXYxFHutorfRImY8TNubevs+8+6Sjw=
// RA_STRING2=U2FsdGVkX1+7EBoxpKZdEtYXEBfHD+fIe5qrAeDKTa8=
// RA_STRING3=Gundel
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(7,30)
#define End_Cloud_Before NumMins(20,00)
#define Lightning_Change_per_Cloud 55
  // Add Random Lightning modes
#define Slow 0    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 1    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 2    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 3   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Fast, Mega, Mega2 };
    //ReefAngel.CustomVar[Var_StormMode]=lightningMode;
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
        switch (lightningMode) {
        case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
        int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
        for (int i=0; i<a; i++)
          analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
          int randy=random(20,80);    // Random number for a delay
          if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
          delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
          analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
          delay(random(30,50));                // Wait from 30 to 49 ms
          wdt_reset();
        DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
        DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
      break;
       case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
      if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
          wdt_reset();
      break;
        case Fast:
          wdt_reset();
      break;
        case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          DaylightPWMValue=0;
        delay(1);
        break;
        default:
        break;
    } else {
      cloudindex++;
      if (cloudindex < numclouds)
    //ReefAngel.LCD.Clear(255,0,62,132,132);
  //ReefAngel.LCD.DrawText(0,255,5,62,"C");
  //ReefAngel.LCD.DrawText(0,255,11,62,"00:00");
  //ReefAngel.LCD.DrawText(0,255,45,62,"L");
  //ReefAngel.LCD.DrawText(0,255,51,62,"00:00");
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      //ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart/60));
      if ((cloudstart%60)>=10) x=29; else x=35;
      //ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart%60));
    //ReefAngel.LCD.DrawText(0,255,90,62,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      //ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      //ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Posted: Mon Jun 11, 2018 3:55 pm
You are probably not using dev branch.
I just tested and it compiles without errors.
https://github.com/reefangel/Libraries/archive/dev.zip
Posted: Thu Jul 05, 2018 7:36 am
by madweazl
Would I be able to use this without grabbing an Expansion Hub (currently running an expansion relay plus the original relay)?
Posted: Thu Jul 05, 2018 9:29 am
Yes
Posted: Tue Oct 23, 2018 2:38 am
by GiraffeCat
Received my new Cloud WiFi Attachment today. Connected to its Wifi, entered all four required fields, and uploaded code via the Web Wizard. Connected the attachment, and had the Cyan light for a minute, and then just the blinking Magenta. Logged into my router and found the attachment was connected. Uploaded the code again and no change. Going to the uapp online tells me:
Cloud Server: Connected
Last Updated: Never
Forum Username: Unknown
Reset the WiFi attachment and input all four fields again ensuring correct username and password for the router and the forum. No change.
Do I need to put anything in the code generated by the Web Wizard? I noticed the web wizard left a few things out in regards to my expansion relays and the dimming expansion, so maybe it is leaving something else out? Do I need to put the forum username and password in the code like the old WiFi adapter?
Tried putting in the username and password like the old Wifi adapter and it wouldn't compile. (Didn't think I needed to since the Cloud attachment gets them up front, but tried anyway...)
Screenshots attached.
Any help would be appreciated.
Thank you in advance,
Dan
