RA reboots using cloud wifi
PostPosted: Thu Jan 19, 2017 4:23 pm
Ok, cant copy and past so I will type it.
cloud wifi connected with USB-TLLcable on com 3 57600baud. As soon as i open the serial monitor I get this:
GET /r99 HTTP/1.1
Host: 73.148.165.18:2000
This repeats forever. Now I open the Uapp on the web and I get:
GET /r99 HTTP/1.1
cloud:all:0 GET /r99 HTTP/1.1
GET /r99 HTTP/1.1
This repeats every time I open the Uapp.
Hope this helps.
-James-
PostPosted: Thu Jan 19, 2017 6:05 pm
It looks good as far as the cloud command.
I do see the pings for the Client suite.
Can you turn it off and see if it makes any difference?
It should show only "cloud:all:0"
The other requests are coming from the Client suite.
PostPosted: Thu Jan 19, 2017 8:18 pm
Do you mean the Reef Angel client suite , that runs the services in the background, by Dave Molton?
-James-
PostPosted: Thu Jan 19, 2017 9:21 pm
correct.
Shut that service off and see if that makes any difference on the log and rebooting.
PostPosted: Fri Jan 20, 2017 5:19 pm
Followed your directions and this is what I see in the serial monitor:
cloud:all:0
Still reboots RA when I connect with the Uapp.
-James-
PostPosted: Fri Jan 20, 2017 5:28 pm
Ok, so let's try the other end now.
Plug the usb-ttl on RA instead of wifi attachment.
Open serial monitor at 57600 baud and make sure that you have Both CR & LF selected.
Then, send this string "cloud:all:0 ". Note that there is a space after 0.
Paste the log.
Does it reboot RA?
PostPosted: Fri Jan 20, 2017 6:30 pm
Yes it rebooted. As a matter of fact it rebooted when I hooked up the usb to the pc, started the IDE and started the serial monitor. I received data after each reboot and after I send the cloud:all: command like this;
CLOUD:SAL:0
CLOUD:PHE:0
CLOUD:PAR:0
CLOUD:CEXP0:0
CLOUD:CEXP2:0
CLOUD:ATOLOW:1
CLOUD:BID:1
CLOUD:PWMD:100
CLOUD:PWMDO:255
CLOUD:R:251
CLOUD:ROFF:255
CLOUD:T1:766
CLOUD:PH:776
-James-
PostPosted: Fri Jan 20, 2017 7:17 pm
I just can't replicate the problem :(
PostPosted: Fri Jan 20, 2017 7:27 pm
The controller does reboot everytime the com port is opened. So it is normal for it to reboot when you plug cable or open serial monitor.
One thing odd in that log is the fact that it is showing SAL, PHE, PAR and other stuff that wasn't supposed to be there when you reboot RA.
This is what I get when I reboot RA with the same code:
CLOUD:BID:1
CLOUD:PWMDO:255
CLOUD:PWMAO:255
CLOUD:R:235
CLOUD:ROFF:255
CLOUD:PH:438
And this is what I get when I send the cloud:all:0 command:
CLOUD:ATOLOW:0
CLOUD:ATOHIGH:0
CLOUD:EM:0
CLOUD:EM1:0
CLOUD:REM:0
CLOUD:BID:1
CLOUD:AF:0
CLOUD:SF:0
CLOUD:PWMD:0
CLOUD:PWMA:0
CLOUD:PWMDO:255
CLOUD:PWMAO:255
CLOUD:R1:0
CLOUD:ROFF1:0
CLOUD:RON1:0
CLOUD:R2:0
CLOUD:ROFF2:0
CLOUD:RON2:0
CLOUD:R3:0
CLOUD:ROFF3:0
CLOUD:RON3:0
CLOUD:R4:0
CLOUD:ROFF4:0
CLOUD:RON4:0
CLOUD:R5:0
CLOUD:ROFF5:0
CLOUD:RON5:0
CLOUD:R6:0
CLOUD:ROFF6:0
CLOUD:RON6:0
CLOUD:R7:0
CLOUD:ROFF7:0
CLOUD:RON7:0
CLOUD:R8:0
CLOUD:ROFF8:0
CLOUD:RON8:0
CLOUD:ALARM:0
CLOUD:PWMD2:0
CLOUD:PWMA2:0
CLOUD:PWMD2O:0
CLOUD:PWMA2O:0
CLOUD:WL:0
CLOUD:WL1:0
CLOUD:WL2:0
CLOUD:WL3:0
CLOUD:WL4:0
CLOUD:HUM:0
CLOUD:DCM:0
CLOUD:DCS:0
CLOUD:DCD:0
CLOUD:DCT:0
CLOUD:PWME0:0
CLOUD:PWME1:0
CLOUD:PWME2:0
CLOUD:PWME3:0
CLOUD:PWME4:0
CLOUD:PWME5:0
CLOUD:PWME0O:0
CLOUD:PWME1O:0
CLOUD:PWME2O:0
CLOUD:PWME3O:0
CLOUD:PWME4O:0
CLOUD:PWME5O:0
CLOUD:AIW:0
CLOUD:AIB:0
CLOUD:AIRB:0
CLOUD:RFM:0
CLOUD:RFS:0
CLOUD:RFD:0
CLOUD:RFW:0
CLOUD:RFRB:0
CLOUD:RFR:0
CLOUD:RFG:0
CLOUD:RFB:0
CLOUD:RFI:0
CLOUD:RFWO:0
CLOUD:RFRBO:0
CLOUD:RFRO:0
CLOUD:RFGO:0
CLOUD:RFBO:0
CLOUD:RFIO:0
CLOUD:IO:0
CLOUD:LEAK:0
CLOUD:C0:0
CLOUD:C1:0
CLOUD:C2:0
CLOUD:C3:0
CLOUD:C4:0
CLOUD:C5:0
CLOUD:C6:0
CLOUD:C7:0
CLOUD:R:235
CLOUD:ROFF:255
CLOUD:RON:0
CLOUD:T1:0
CLOUD:T2:0
CLOUD:T3:0
CLOUD:PH:439
CLOUD:ORP:0
CLOUD:SAL:0
CLOUD:PHE:0
CLOUD:PAR:0
CLOUD:CEXP0:0
CLOUD:CEXP1:0
CLOUD:CEXP2:0
CLOUD:CEXP3:0
CLOUD:CEXP4:0
CLOUD:CEXP5:0
CLOUD:CEXP6:0
CLOUD:CEXP7:0
PostPosted: Fri Jan 20, 2017 8:15 pm
Odd. I did load a new program on it tonight before I did your test. It is the same code, I just added a ATO float switch code to it.
Keep in mind that it does NOT reboot if I use the Reef Angel client or the portal. Only the web based Uapp. One more thing, I cannot connect with the standalone Uapp on my iPhone or iPad at all, only the web Uapp. Of course that reboots the controller.
Is nobody else having this problem?
I know this cloud wifi is new, so I am hoping it is a bug somewhere.
-James-
Return to Addons
