Page 1 of 5
RA reboots using cloud wifi
PostPosted: Sat Jan 14, 2017 5:33 pm
by GermanDude
Hi there,
Has anyone had problems with the RA rebooting when you connect to the Cloud WIFI using the web Uapp?
As long as I do not close the browser and stay on the page it fine. If I reconnect using the Uapp the RA reboots and turns my ports back on that I turned off before. This happens with the iPhone, iPad or windows laptop.
Re: RA reboots using cloud wifi
PostPosted: Sat Jan 14, 2017 6:17 pm
I'm gonna try to replicate it.
I think someone else was having this same issue.
PostPosted: Sat Jan 14, 2017 6:30 pm
by GermanDude
Thanks,Roberto.
PostPosted: Tue Jan 17, 2017 5:17 pm
by GermanDude
Here is the code I am running. Still reboots RA+ when I use the Uapp.
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.DelayedOn( Port3,2 );
    ReefAngel.StandardHeater( T1_PROBE,Port5,735,780 );
    ReefAngel.PWM.SetDaylight( PWMSlope( 20,10,23,0,15,100,5,0 ) );
    ReefAngel.CloudPortal();
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
PostPosted: Tue Jan 17, 2017 9:13 pm
I can't seem to be able to replicate this even using your code.
Uapp connects to the cloud server and when I close the browser, the controller is still up and no reboot.
PostPosted: Tue Jan 17, 2017 9:19 pm
I can refresh the page or close browser and reopen and it will still be there.
PostPosted: Tue Jan 17, 2017 9:33 pm
Is it after a certain period of time or it reboots even in the first minute of turning RA on?
PostPosted: Wed Jan 18, 2017 6:38 am
by GermanDude
It was doing this the second I opened the browser page for the Uapp.
I am at work so I will recheck tonight.
PostPosted: Wed Jan 18, 2017 7:44 am
by GermanDude
This ias the code loaded on the cloud wifi module.
In case it helps trouble shooting.
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
//char ssid[32];
//char pass[32];
//char username[16];
//char password[16];
unsigned long client_timeout = millis();
unsigned long wifi_connection = millis();
unsigned long serial_timeout = millis();
unsigned long led_blink = millis();
unsigned long MQTTReconnectmillis = millis();
boolean LED_status = false;
boolean PortalConnection = false;
boolean power_status = true;
boolean data_ready = false;
int status = WL_IDLE_STATUS;
WiFiServer server(2000);
WiFiClient client;
WiFiClient portalclient;
WiFiClient mqttclient;
void mqttcallback(char* topic, byte* payload, unsigned int length);
PubSubClient CloudClient(MQTTServer, MQTTPORT, mqttcallback, mqttclient);
String currentLine = "";                // make a String to hold incoming data from the client
void setup() {
  Serial.begin(57600);      // initialize serial communication
  Serial1.begin(57600);      // initialize serial communication
  pinMode(6, OUTPUT);      // set the LED pin mode
  pinMode(7, OUTPUT);      // set the LED pin mode
  wdt_initialize();
  wdt_enable();
void loop() {
  wdt_reset();
  status = WiFi.status();
  while ( status != WL_CONNECTED) {
    digitalWrite(6, true);
    digitalWrite(7, false);
    if (millis() - wifi_connection > 1000)
      Serial.print("Attempting to connect to Network named: ");
      Serial.println(WIFI_SSID);                   // print the network name (SSID);
      if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
        server.begin();                           // start the web server on port 2000
        printWifiStatus();                        // you're connected now, so print out the status
        digitalWrite(6, false);
        digitalWrite(7, true);
  client = server.available();   // listen for incoming clients
  if (client) {                             // if you get a client,
    Serial.println(F("new incoming client"));           // print a message out the serial port
    while (client.connected()) {            // loop while the client's connected
      if (millis() - client_timeout > 2000) client.stop();
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        Serial1.write(c);                   // send to Reef Angel
      if (Serial1.available())
        char c = Serial1.read();
        //Serial.write(c);
        currentLine += c;
        if (currentLine.length() == 255) {
          SendData();
      if (millis() - serial_timeout > 400)
        if (currentLine.length() > 0) {
          SendData();
          Serial.println();
          client.println();
      if (millis() - led_blink > 50)
        LED_status = !LED_status;
        digitalWrite(6, LED_status);
    // close the connection:
    client.stop();
    Serial.println(F("incoming client disconnected"));
    while (Serial1.available())
      currentLine += c;
      if(c==10) data_ready=true;
      if (millis() - serial_timeout > 200 || data_ready)
          data_ready=false;
          //        Serial.print(currentLine);
          if (currentLine.startsWith("GET"))
            PortalConnection = true;
            Serial.println(F("Connecting to Portal Server"));
            if (portalclient.connect(PortalServer, 80)) {
              Serial.println(F("Connected"));
              // Make a HTTP request:
              portalclient.print(currentLine);
              portalclient.println(F(" HTTP/1.1"));
              portalclient.println(F("Host: forum.reefangel.com"));
              portalclient.println(F("Connection: close"));
              portalclient.println();
              Serial.println(F("Failed to connect"));
          if (currentLine.startsWith("CLOUD:"))
            //Serial.print(currentLine);
            if (currentLine.length() < 32)
              if (CloudClient.connected())
                //Serial.println(F("Publishing "));
                currentLine.replace("CLOUD:", "");
                char pub_buffer[sizeof(CLOUD_USERNAME) + 5];
                sprintf(pub_buffer, "%s/out", CLOUD_USERNAME);
                char pub_msg[currentLine.length() + 1];
                currentLine.toCharArray(pub_msg, currentLine.length() + 1);
                CloudClient.publish(pub_buffer, pub_msg);
              Serial.print(F("Error on incoming data: "));
              Serial.println(currentLine.length());
          currentLine = "";
    while (portalclient.available()) {
      char c = portalclient.read();
      //      Serial.write(c);
    if (PortalConnection && !portalclient.connected()) {
      //      Serial.println();
      Serial.println(F("Disconnecting from Portal Server"));
      portalclient.stop();
  CloudClient.loop();
  if (millis() - MQTTReconnectmillis > 5000)
    if (!CloudClient.connected())
      char sub_buffer[sizeof(CLOUD_USERNAME) + 6];
      Serial.println(F("MQTT Connecting..."));
      sprintf(sub_buffer, "RA-%s", CLOUD_USERNAME);
      if (CloudClient.connect(sub_buffer, CLOUD_USERNAME, CLOUD_PASSWORD))
        sprintf(sub_buffer, "%s/in/#", CLOUD_USERNAME);
        Serial.println(F("MQTT succeeded"));
        CloudClient.subscribe(sub_buffer);
        Serial.println(F("MQTT failed"));
        CloudClient.disconnect();
  if (analogRead(0) < 600 && power_status)
    power_status = false;
  if (analogRead(0) > 600 && !power_status)
void SendData()
  currentLine = "";
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  Serial1.print("cloud:");
  for (int a=0;a<length;a++)
    Serial1.write(payload[a]);
    Serial.write(payload[a]);
  Serial1.print(" ");
  Serial.println();
void wdt_initialize()
  GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
  GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
                      GCLK_GENCTRL_GENEN |
                      GCLK_GENCTRL_SRC_OSCULP32K |
                      GCLK_GENCTRL_DIVSEL;
  while (GCLK->STATUS.bit.SYNCBUSY);  // Syncronize write to GENCTRL reg.
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
                      GCLK_CLKCTRL_CLKEN |
                      GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
  WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CTRL reg.
  WDT->CONFIG.reg = WDT_CONFIG_PER(0xA);  // 0xA = 8192 ms
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CONFIG reg.
  WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
  WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
  WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX19/au2AykFSeuvh7Ef0WBhNw2fGDTBJTmA=
// RA_STRING2=U2FsdGVkX18OMaDMIUP5GZQUBkPiWBixOeo/eh7U/b8=
// RA_STRING3=Dakota
PostPosted: Thu Jan 19, 2017 12:28 pm
Let's try this....
We are going to use the cloud wifi attachment and the USB-TLL cable.
1. Connect the cloud wifi to the usb ttl cable. Black wire to the right. This should power the unit on.
2. Using the arduino ide, open serial monitor and make sure you are using 57600 baud rate.
3. Open Uapp on your browser, it should print some stuff on serial monitor window.
Paste here.
