Random Lights on With Dimming Module
Posted: Sat Feb 04, 2017 10:33 am
by robmwpropane
Ok guys, it doesn't happen often. Has happened like 3 times since I incorporated the dimming module. I'll go the fish tank and the lights are on before scheduled time, it does not show in the app, and I've lost control of them ie, I can't ramp them up or down with the app. And I'm pretty sure at this point they've been on all night. I have to unplug the dimming module to "reset" it and then all is back to normal. What the world is going on?
It's beginning to freak me out.
Fwiw, I upload my code w/the wizard to internal memory. Have not stepped outside the wizard yet. This has me upload the code twice every time, which I do not fully understand, and don't think I need to do, but don't know what to do instead.
No bus locks, no errors, nothing. They just randomly stay on.
Here is my code;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.Portal( "****" );
    ReefAngel.DDNS( "****" ); // Your DDNS is ****.myreefangel.com
Re: Random Lights on With Dimming Module
Posted: Sat Feb 04, 2017 8:24 pm
by robmwpropane
Alright, I think my issue is again with my DCP pump. I believe it's causing interference with my led lights. Does anyone know a way to shield the cat 6 wire without making it look like crap? Some kind of electro magnetic shield? I love this pump, but it's driving me nuts.
Posted: Mon Feb 06, 2017 6:20 am
by robmwpropane
Still having issues with this. Not 100% sure it's the DC pump. My lights sometimes come on, don't come on, come on half way, don't shut off. Happened again last night, they were still on after scheduled time to be off?
Any ideas? Anyone experience any of these symptoms?
I have a 25' shielded cat5 cable ordered from amazon. Am going to try shielding all control wires, see what that does.
Posted: Thu Feb 09, 2017 3:53 am
by cosmith71
What kind of lights? How are you controlling them, are you switching off a relay or dimming them to zero?
Posted: Thu Feb 09, 2017 5:27 am
by robmwpropane
cosmith71 wrote:What kind of lights? How are you controlling them, are you switching off a relay or dimming them to zero?
Steve's LED diy, 0-10 PWM
Controlling them via binders app
dimming to "0"
I have since switched my DC pump back to the stock controller and have all of it's wires on the other side of the tank (6' away). This seems to have fixed the problem.
Using the A1 controller to control the pump means I have to run a control wire near the RA (to the standard dimming on the relay box). This seems to be the source of my interference. I have ordered some shielded cat5 wire with the aluminum in it, so hopefully that will fix it. Plan to install this on both the dimming module control wires, and to the DC pump, hopefully this weekend.
