Bus Lock from new dimming expansion
PostPosted: Sat Mar 11, 2017 8:11 am
I just purchased the dimming expansion module and I keep getting Bus Locks but not til after a few hours. This morning I woke up and had a bus lock. I unplugged the dimming module and the RA started working again.
What would cause this? Is it the cable or the module itself?
Also I can hear my relays randomly clicking and I don't have a wavemaker setting on any ports. The are either always on or always off with the exception of my ATO Pump,Lights and heaters.
Here is a list of my equipment.
RA+
Expansion Hub
Dimming Expansion
Relay Expansion
Main Relay
pH probe
Temp probe
PostPosted: Sat Mar 11, 2017 6:45 pm
Try a different port in the hub.
Does it make any difference?
PostPosted: Sun Mar 12, 2017 5:03 pm
I switched both the Dimming Expansion and the Relay expansion into different ports and so far so good
PostPosted: Mon Mar 13, 2017 7:05 am
That worked
PostPosted: Tue Mar 14, 2017 8:44 am
Just got another Bus lock
PostPosted: Mon Mar 20, 2017 8:11 pm
You wouldn't happen to have a LEDs and T5's, would you?
PostPosted: Tue Mar 21, 2017 10:12 am
I have all LEDs on LDD drivers. Roberto helped me find the problem. I was extending the VGA cables from the reef angel head unit to the main relay box, then extending the expansion relay to the secondary relay box.
This was creating interference
Return to Addons
